Calculating Torsion: Understanding the Role of Force and Distance
  • Thread starter Amaelle
  • Tags
    Torsion
In summary, the conversation covers the topic of calculating torsion using the torsion formula, the difference between shear stress and torsion, the applicability of the torsion formula to any shape or object, how to determine the torsion constant for a specific object, and the units used to measure torsion. The torsion formula is T = κ * J, where T is the torsion, κ is the torsion constant, and J is the polar moment of inertia. Shear stress is a two-dimensional force, while torsion is a three-dimensional force. The torsion formula can be applied to any shape or object as long as the necessary information is known. The torsion constant can be calculated using mathematical equations, found in tables
Amaelle
310
54
Summary:: trying to calculate the torsion but couldn´t understand the solution
Greetings
I´m trying to understand why the multiplied the Force by a/2 to find the torsion in te point c
thank you!
They are dividing the force F by 2, not the a distance.
F/2 is the magnitude of each reaction force at support points A and E.
  • Love
Likes Amaelle
thanks a million!
You are welcome, Amaelle. :smile:
Likes Amaelle
FAQ: Calculating Torsion: Understanding the Role of Force and Distance
What is torsion and why is it important to calculate it?
Torsion is the twisting force that occurs when a body is subjected to a torque or moment. It is important to calculate torsion because it can affect the stability and strength of a structure, and failure to properly account for torsion can lead to structural damage or collapse.
What are the units of measurement for torsion?
The units of measurement for torsion are typically expressed in Newton-meters (Nm) or pound-feet (lb-ft). These units represent the amount of force applied at a distance from the center of rotation, which results in a twisting motion.
What is the formula for calculating torsion?
The formula for calculating torsion is T = kθ, where T is the torsion or twisting moment, k is the torsion constant, and θ is the angle of twist. The torsion constant is a property of the material and cross-sectional area of the object, and can be determined through experimentation or reference tables.
How do you calculate torsion in a circular cross-section?
To calculate torsion in a circular cross-section, you can use the formula T = (π/2)GθR^3, where G is the shear modulus of the material, θ is the angle of twist, and R is the radius of the cross-section. This formula assumes that the material is homogeneous and isotropic.
What are some common applications for calculating torsion?
Calculating torsion is important in many engineering and scientific fields, including structural design, mechanical engineering, and materials science. Some common applications include analyzing the strength of beams and columns, designing shafts and axles, and predicting the behavior of materials under torsional stress.
