Sia001
- 1
Hey all I am a newbi and wondering how to do this conversion. When i see a water pump which is 1400G/hour at that rate what would be the psi?
For example my garden hose is about 40psi and at that rate it would mean a curtain g/ph based on say a 15mm outlet radius.
Im trying to figure out what pump i need for my water fall feature for my pond, but as a the filter needs to sit bellow the pond i will need extra power for the water to travel up about 600mm and feed into a 300mm spillway, so i was trying to do a experiment with my garden hose and time to see how long it takes to fill say 2 gallons, based on a 40psi and 15mm outlet and 600mm hose held up 600mm high from the ground to see what sort of water flow i get so i can have an idea what sort of pump i need.
the pump I am looking at is 530g/h with power of 55W with 19mm outlet
