How to find the horizontal distance from projectile motion?
In summary, a projectile is fired horizontally from a gun that is 45.0 m above flat ground, with an initial speed of 250 m/s. The projectile remains in the air for approximately 3.03 seconds and strikes the ground at a horizontal distance of 757.5 m from the firing point. The magnitude of the vertical component of its velocity at impact is approximately 29.7 m/s. The initial vertical velocity is zero, and the final vertical velocity is -29.7 m/s.
Eclair_de_XII
1,083
91
"A projectile is fired horizontally from a gun that is 45.0 m above flat ground, emerging from the gun with a speed of 250 m/s. (a) How long does the projectile remain in the air? (b) At what horizontal distance from the firing point does it strike the ground? (c) What is the magnitude of the vertical component of its velocity as it strikes the ground?"
##v_y^2=(v_0sinθ_0)^2-2g(y-y_0)##
##v_y=v_0sinθ-gt##
##x-x_0=(v_0cosθ_0)t##
##x_0=0m##
##y_0=45m##
##y=0m##
##v_0=250\frac{m}{s}##
Answer as given by the book:
##x = 758 m##
I make gravitational acceleration to be positive, because as it hits the ground, the bullet is gaining speed; not losing.
##0=[(250\frac{m}{s})(sinθ)]^2+2(9.8\frac{m}{s^2})(0m-45m)##
##882\frac{m^2}{s^2}=(62500\frac{m^2}{s^2})(sin^2θ)##
##sinθ=-0.1188##
I make the value of sinθ to be negative, because I'm making the gun to face the rightward direction. If it shoots, then it goes down, from the path driven by its velocity.
##θ=-6.823°##
##v_y=v_0sinθ-gt##
##0=(250\frac{m}{s})(sin(-6.823°))+(9.8\frac{m}{s^2})(t)##
##-(9.8\frac{m}{s^2})(t)=(-29.7\frac{m}{s})##
##t=3.03s##
Then here's where I'm having conflicting numbers, when I calculate the horizontal distance.
##x-x_0=(v_0cosθ)t##
##x=(250\frac{m}{s})(cos(-6.823°))(3.03s)=752m≠758m##
##v_y=v_0sinθ-gt##
##x_0=0m##
##y_0=45m##
##y=0m##
##x = 758 m##
##sinθ=-0.1188##
##θ=-6.823°##
##v_y=v_0sinθ-gt##
##t=3.03s##
I'm not following your calculations. The vertical motion is the same as if the projectile were dropped from that same height. How long does it take an object to fall that distance if dropped from rest?
And given the horizontal velocity and that time, how far does the projectile go before it hits the ground.
And how fast is an object going vertically when dropped from that height and it hits the ground?
I make the final velocity (when the bullet hits the ground) to be zero.
ROTFLMAO! :smile:
Uh... Okay, so what don't you understand about my calculations?
##v_y=v_0sinθ-gt##
##x_0=0m##
##y_0=45m##
##y=0m##
##x = 758 m##
##sinθ=-0.1188##
##θ=-6.823°##
##v_y=v_0sinθ-gt##
##t=3.03s##
The reason your range value differs slightly from the book value is that you have calculated the range assuming the gun is pointed below the horizontal. That's what the factor cos (-6.823°) would indicate. The angle of firing, θ0 ≠ θ on impact.
The gun is fired horizontally, according to the problem statement, so the projectile is traveling horizontally as it leaves the gun. This means the angle θ0 = 0°, and the initial vertical velocity of the projectile v0 ⋅ sin θ0 = 0 as it leaves the gun. This also implies that the horizontal velocity is v0 ⋅ cos θ0 = v0 = 250 m/s, as specified.
The projectile stays in the air only as long as it takes it to free fall from the elevation of 45 m.
Likes berkeman
So if I drop you off a 45m building, you will be going 0m/s when you reach the ground and will not be hurt. And I will not be in trouble with the Physics Police...
Is it really zero?
SteamKing said:
That's what the factor cos (-6.823°) would indicate. The angle of firing, θ_0 ≠ θ on impact.
Oh, so it's just ##(250\frac{m}{s})(cos0°)(3.03s)=757.5m##
Yeah... I guess you have a point. Still, though, the book says that the velocity just before the bullet reaches the ground is equal to ##29.7\frac{m}{s}##, which is what I calculated. But then that's when I set final velocity to zero... I guess that the initial velocity is the one that's zero? Since horizontal motion doesn't affect vertical motion, and the vertical velocity would be just the same as if there were no horizontal motion at all. Anyway, I think I have my answers. It asks for the magnitude of the final vertical velocity, which is ##|-29.7\frac{m}{s}|=29.7\frac{m}{s}. Anyone feel free to correct me.
Correct. Problems like this are just about separating the vertical and horizontal motion. If the initial launch angle were different from zero from the horizontal, you would use trig to figure out the vertical component of velocity. As it is, it's just a simple drop problem with a constant horizontal velocity. :smile:
Related to How to find the horizontal distance from projectile motion?
1. What is projectile motion?
Projectile motion is the motion of an object through the air or space under the influence of gravity. It follows a curved path known as a parabola.
2. How do you find the horizontal distance from projectile motion?
To find the horizontal distance from projectile motion, you can use the formula distance = velocity * time, where velocity is the initial velocity of the object and time is the total time the object is in motion.
3. What is the importance of finding the horizontal distance from projectile motion?
Finding the horizontal distance from projectile motion is important as it helps in predicting the path and landing point of the object. This information is useful in various fields such as sports, engineering, and military operations.
4. What factors affect the horizontal distance in projectile motion?
The horizontal distance in projectile motion is affected by the initial velocity, angle of projection, and the force of gravity. These factors can be manipulated to control and adjust the horizontal distance of the object.
5. Can the horizontal distance be greater than the vertical distance in projectile motion?
Yes, the horizontal distance can be greater than the vertical distance in projectile motion. This occurs when the object is projected at an angle closer to the horizontal plane rather than the vertical plane. In this case, the horizontal velocity will be greater than the vertical velocity, resulting in a longer horizontal distance.
