Leandro de Oliveira
- 2
I have a problem to put the complex number in mode (1000/3, ∠36.87), apparently the division simbol gives some syntax error
thx for reply, but I've already tried this the only solution I've found was (1000, ∠36.87)/3Tom.G said:I don't have a 50G but you might try putting parens around the 1000/3, entering it as ((1000/3), ∠36.87).
Leandro de Oliveira said:thx for reply, but I've already tried this the only solution I've found was (1000, ∠36.87)/3
To enter a complex number with a fraction on the HP 50G calculator, you can use the following format: a/b+c/d*i
, where a/b
represents the real part and c/d
represents the imaginary part. Note that the fraction must be entered in decimal form.
To perform basic arithmetic operations with complex numbers containing fractions on the HP 50G calculator, you can use the built-in complex number functions such as Re()
for the real part and Im()
for the imaginary part. You can also use the +
, and /
symbols to add, subtract, multiply, and divide complex numbers.
Yes, you can convert a complex number with a fraction into polar form on the HP 50G calculator by using the CPLX
function. This function takes two arguments, the real and imaginary parts, and converts the number into polar form with the magnitude and angle.
The HP 50G calculator has a built-in solver that can handle equations involving complex numbers with fractions. You can access this solver by pressing the SOLVE
key and then entering the equation in the format a/b+c/d*i=0
. The calculator will then solve for the unknown variable and display the result.
Yes, you can use the NUM
function on the HP 50G calculator to convert a complex number with a fraction into decimal form. Simply enter the number in the format a/b+c/d*i
and then press the NUM
key to convert it into decimal form.
