I am having trouble solving this equation
  • Thread starter billllib
In summary: When you simplify an equation, you should always forget the "=" sign and just use the equals sign (=). Usually when you simplify an equation, you get a simpler equation that looks like this: ##\frac{d}{dx}=\frac{e}{f}##
billllib
77
I am having trouble solving this equation?
## \frac { {1 - \frac {v^2} {c^2}}} {\sqrt {1 - \frac {v^2} {c^2}}} ##
## \frac {\sqrt {1 - \frac {v^2} {c^2}}} { {1 - \frac {v^2} {c^2}}} ## I got the equation wrong this is the correct equation.
billllib said:
Homework Statement:: I am having trouble solving this equation?
Relevant Equations:: ## \frac { {1 - \frac {v^2} {c^2}}} {\sqrt {1 - \frac {v^2} {c^2}}} ##
That's an expression, not an equation (an equation has an "=" sign). Are you asked to simplify the expression? Subject to any conditions?
As @berkeman said, this is an expression, not an equation. You can't "solve" an expression. Most likely the instructions for the problem ask you to simplify this expression.
Hint:
$$\frac{\sqrt x}{x} = \frac 1 {\sqrt x}$$
is it possible from the expression
##\frac {\sqrt {1 - \frac {v^2} {c^2}}} { {1 - \frac {v^2} {c^2}}} ##
to get
## \frac 1 {\sqrt {1 - \frac {v^2} {c^2}}} ##
to get
Have you made any attempt to do so? Our goal is to help you learn how to do things, no to do them for you.
EDIT: also, did you read post #3?
I don't know where to start.
But you haven't responded to our questions about what you are supposed to do. You've already been shown how to simplify the expression some, do you understand that? And unless you post the full text of the problem statement that you were given, there's not much more that we can do. Did your problem statement say "solve this equation" even though it is just an expression? If it said to solve it, did it say what to "solve" it for?
Sorry my fault. Its not a problem statement. I Just made up this example. My goal was to take the
## x_A = gamma (x_B - vt_B) ## and get ## x_B = gamma (x_A - vt_A) ##
To get this I was told to combine ## x_A = gamma (x_b - vt_b) ## , ## t_A = gamma (t_B - \frac{ vx} {c^2}) ##
Maybe this is bad advice. Eventually I get ## \frac {\sqrt {1 - \frac {v^2} {c^2}}} { {1 - \frac {v^2} {c^2}}} ## along with some other terms.
This is only 2 dimensions of a Lorentz transform.
You have not answered the question " You've already been shown how to simplify the expression some, do you understand that? " You HAVE been shown. DO you understand that? If not, just say so, but please make some effort.
OK sorry. Is it okay if i post an image from imgur? Or in the future do you prefer latex math?
Would something like this image work?
It might be OK if your writing was legible.
Yes, very much
No, not at all. It looks like you are saying that ##\sqrt{1 - \frac{v^2}{c^2}} = 1##, which would be true only if v = 0.
I'm having a hard time understanding how you can be studying Lorentz transforms, but are unable to simplify an expression that is at roughly the 9th grade algebra level.
$$\frac{\sqrt x} x = \frac{\sqrt x}{(\sqrt x)^2}$$
I'm hoping you can simplify that. If not, you really should brush up on plain old algebra.
I am a little rusty and have forgot a lot of stuff. Is that Okay?
I always thought that if you had a variable, an example could be, ##x## and wanted to get the other side of the equation and there is nothing there you just add a ##1## to the other side. Ex ##x = 1##
OK, you thought something completely wrong. That happens. Now reread post #11 and act on it.
to get
I don't want to put you off, but undergraduate level physics is going to be tough/impossible if you don't see that those two expressions are obviously equal. It's not a question of whether it is possible to get from one to the other, but you should see getting from one to the other as an obvious single algebraic step.
You need some serious mathematics revision before you can tackle SR. You're not just a little rusty.
Amen to that!
FAQ: I am having trouble solving this equation
How do I start solving an equation?
The first step in solving an equation is to simplify it by combining like terms and using inverse operations to isolate the variable on one side of the equation.
What are inverse operations?
Inverse operations are mathematical operations that undo each other. For example, addition and subtraction are inverse operations, as well as multiplication and division.
What do I do if I get stuck while solving an equation?
If you get stuck while solving an equation, try working backwards or breaking the equation into smaller parts. You can also ask for help from a teacher or tutor.
Can I check my answer to see if it is correct?
Yes, you can always check your answer by plugging it back into the original equation and seeing if it satisfies the equation. You can also use a calculator to verify your answer.
How can I improve my equation-solving skills?
Practice is key to improving your equation-solving skills. You can also try to understand the concepts behind the equations and ask for help when needed. Additionally, reviewing and understanding your mistakes can also help you improve.
