Identify which of the ff. object will be positive or negative charge
In summary, based on the Triboelectric series, the objects with the higher position will acquire a positive charge while the objects with the lower position will acquire a negative charge when rubbed together. In case of two rubbers being rubbed together, it is possible for both to gain positive charges. The suggested technique is to consult a textbook for further information.
Megaevelie
1) Hand and Hair
2) PVC and Tetlon
3) Glass and Poly ester
4) Rubber and rubber
5) Hand and wood
1) Hand and Hair
2) PVC and Tetlon
5) Hand and wood
What technique is suggested? Look it up in a textbook?
I think Triboelectric series is the reference here. But I do not know what happens when both rubbers are rubbed. Is it possible that they both gain positive charges?
FAQ: Identify which of the ff. object will be positive or negative charge
What is the difference between a positive and negative charge?
Positive and negative charges refer to the presence or absence of electrons in an object. A positive charge indicates that an object has lost electrons, while a negative charge indicates that an object has gained electrons.
How do you determine if an object has a positive or negative charge?
The charge of an object can be determined by observing its interaction with other charged objects. If it repels a positively charged object, it has a positive charge. If it repels a negatively charged object, it has a negative charge.
Can an object have both a positive and negative charge?
No, an object cannot have both a positive and negative charge at the same time. Like charges repel each other, so an object will either have a positive or negative charge, but not both simultaneously.
What causes an object to become positively or negatively charged?
An object can become positively or negatively charged through the gain or loss of electrons. This can occur through friction, contact with other charged objects, or exposure to electromagnetic radiation.
How does the charge of an object affect its behavior?
The charge of an object affects its behavior by influencing its interactions with other charged objects. Oppositely charged objects will attract each other, while similarly charged objects will repel each other.
