If problem states acceleration is constant what is the acceleration?
In summary, the problem states that a bike rider experiences constant acceleration while gliding down a steep hill. After 4.50 seconds, the rider reaches a final velocity of 7.50 m/sec and travels a total displacement of 19.0 meters. Using the kinematic equations, the initial velocity can be calculated using the given data without making any assumptions.
survivorboiii
If problem states "acceleration is constant" what is the acceleration?
While gliding down a steep hill, a bike rider experiences constant acceleration. After 4.50 seconds, he reaches a final velocity of 7.50 m/sec. The bike's displacement was 19.0 meters.
I know that I'm supposed to be using one of the kinematics equations. But what do I put as acceleration when it says constant acceleration? What does variable a equal to?
t=4.5
vf=7.5 m/s
d= 19m
Find vi
You've got time, the final velocity, and the total displacement. What equation, which includes acceleration and initial velocity, would you use which contains all of these quantities?
If you write down this kinematic equation and start plugging in what you know, you should be able to determine what 'a' is.
Hint: This is why you study algebra in school.
There are two of them that includes all three given variables, but they also include acceleration and initial velocity, which I don't have. How do I solve for two unknown variables?
I just had the idea that the initial velocity would be 0 m/s
You have two equations and two unknowns. In algebra, this is where you would be using substitution or elimination, although there's actually an easier way to do this problem since one of the kinematic equations already contains only one of your unknowns.
Edit: I guess you actually only have one unknown, since you aren't required to find acceleration.
FAQ: If problem states acceleration is constant what is the acceleration?
What is constant acceleration?
Constant acceleration is the rate of change of an object's velocity that remains the same over time. This means that the object experiences the same amount of change in velocity in each time interval.
How can constant acceleration be calculated?
Constant acceleration can be calculated using the formula a = (vf - vi) / t, where a is the acceleration, vf is the final velocity, vi is the initial velocity, and t is the time interval.
What is the difference between constant acceleration and variable acceleration?
Constant acceleration refers to a situation where the acceleration of an object remains the same over time, while variable acceleration refers to a situation where the acceleration changes over time.
Is constant acceleration the same as uniform acceleration?
Yes, constant acceleration and uniform acceleration are the same. They both refer to a situation where the acceleration of an object remains the same over time.
What are some real-life examples of constant acceleration?
Some real-life examples of constant acceleration include a car driving at a constant speed on a straight road, a ball falling under gravity, and a rocket launching into space with a constant thrust.
