If two white-dwarf stars combined together,there will be supernova?which type?-
  • Thread starter magnetar
  • Tags
    Stars Type
In summary: Safer than we thought!In summary, if two white-dwarf stars combined together, there will be supernova? which type? If two neutron stars combined together, there will be supernova? which type? If a white-dwarf and a neutron star combined together, there will be supernova? which type?
magnetar
83
If two white-dwarf stars combined together,there will be supernova?which type?---
(1)If two white-dwarf stars combined together,there will be supernova? which type?
(2)If two neutron stars combined together ,there will be supernova?
(3)If a white-dwarf and a neutron star combined together ,there will be supernova?
Thank you in advance!
Astronomy news on Phys.org
In all cases I suspect the answer would be yes however the question is how these collisions would occur? Stars not associated with each other (i.e. not a binary system) almost never collide, there is simply to much space between stars for there to be a reasonable chance that they will ever collide.
Interactions between stars in a binary system do lead to supernovae, usually when once star expands while in its red giant phase and sheds some material onto the companion star. Two white dwarves and/or neutron stars orbiting one another will have no way to exchange any mass or collide since the orbit is stable and they are in their final stage of evolution.
Accordong to GR,this system will emit gravitational wave ,so they will gradually approach each other, finally they combind together!
Oh yes, good point!
I'm no expert on this but I would imagine the rate at which they lose energy and spiral inwards would be pretty slow such that I would be surprised if the Universe was old enough for any pairs of Neutron stars to have spiraled in sufficiently to do this. I may well be wrong though, but that would be my suspicion.
You can login this website ,you will find the answer http://www.astro.cornell.edu/academics/courses/astro201/psr1913.htm
The pulsar's orbit is shrinking with time as shown in this diagram; currently, the orbit shrinks by about 3.1 mm per orbit. The two stars should merge in about 300 million years from now.
(Figure from Weisberg et al. 1981)
Looks like the orbits shrink a lot quicker than I expected. I guess they may well cause some kind of SN when they merge then.
I should stick to answering the question that I know the answer to :redface:
A neutron star is almost dense enough to be a black hole. I wonder if there is a point where a neutron star and a companion would spiral close enough to each other, without colliding, where their combined gravity can form an event horizon, sparing the universe the fate of being bathed in the awesome radiation emitted if they ever did collide?
Although this event is powerful, if the distance is farther enough ,we are all very safe !
FAQ: If two white-dwarf stars combined together,there will be supernova?which type?-
What is a white dwarf star?
A white dwarf star is a small, dense star that is formed when a star with a mass similar to our sun runs out of fuel and collapses. They are about the size of Earth but contain about a sun's worth of mass.
What happens when two white dwarf stars combine together?
When two white dwarf stars combine, they will undergo a process called a supernova, which is a powerful explosion that destroys the star.
Will the supernova be a Type I or Type II?
The supernova caused by the combination of two white dwarf stars is classified as a Type Ia supernova. This type of supernova occurs when a white dwarf star accumulates matter from a companion star, causing it to exceed its maximum mass and explode.
How does the combination of two white dwarf stars result in a supernova?
As the two white dwarf stars orbit each other, they gradually lose energy and spiral closer together. When they finally merge, the intense gravitational forces cause the stars to collapse and explode, creating a supernova.
What are the implications of a supernova caused by the combination of two white dwarf stars?
This type of supernova is important in understanding the evolution of stars and the production of elements in the universe. It also has significant implications for the study of dark energy and the expansion of the universe.
