Inequality proof (Spivak 1.6-b)
In summary, the conversation discusses proving the inequality x^n < y^n for odd values of n when x < y. The attempted solution breaks down into three cases: when 0 ≤ x < y, when x ≤ 0 < y, and when x < y ≤ 0. The first two cases are proven using the closure properties of positive and negative numbers. The third case is proven using the insights gained from the first two cases. The conversation concludes with confirmation that the proofs for cases 1 and 2 are correct and a suggestion to use the previously proven cases to solve case 3.
carlosbgois
68
Prove that if x < y, and n is odd, then x[itex]^{n}[/itex]< y[itex]^{n}[/itex]
My attempt was to solve three different cases:
Case 1: If 0 [itex]\leq[/itex] x < y, we have
y-x > 0
y*y*...*y > 0 (closure of the positive numbers under multiplication)
x*x*...*x [itex]\geq[/itex] 0
y[itex]^{n}[/itex]-x[itex]^{n}[/itex] = (y-x)(y[itex]^{n-1}[/itex] + y[itex]^{n-2}[/itex]x +...+ yx[itex]^{n-2}[/itex] + x[itex]^{n-1}[/itex])
So, as every piece of the second member of this last equation is positive, their sums and multiplications are also positive, hence proving that y[itex]^{n}[/itex] > x[itex]^{n}[/itex]
Case 2: If x[itex]\leq[/itex] 0 < y, we have: x[itex]^{j}[/itex] [itex]\leq[/itex] 0 (j is odd), and also y[itex]^{j}[/itex] > 0, which is the same as -y[itex]^{j}[/itex] < 0. Now, as we have closure under sum, then x[itex]^{n}[/itex] + (-y[itex]^{n}[/itex]) < 0, so y[itex]^{n}[/itex] > x[itex]^{n}[/itex]
Case 3: If x < y [itex]\leq[/itex] 0 ... ?
Are my proofs of case 1 and 2 ok? What should I do in case 3?
Thanks
For (2), if x< 0< y, for odd n, if [itex]x^n< 0[/itex] and [itex]0< y^n[/itex]. That's all you need to say.
For (3), if x< y< 0, then -x> -y> 0. And, of course, for n odd, [itex](-x)^n= -x^n[/itex]. Use (1) that you have already proved.
Thanks! It's actually simple, but sometimes I find hard to have these insights.
FAQ: Inequality proof (Spivak 1.6-b)
What is "Inequality proof (Spivak 1.6-b)"?
"Inequality proof (Spivak 1.6-b)" is a mathematical concept that involves proving an inequality statement or equation using the techniques and principles outlined in Michael Spivak's book "Calculus". It is often used in advanced calculus and mathematical analysis courses.
What is the purpose of an inequality proof?
The purpose of an inequality proof is to show that a mathematical statement or equation is true for all values in a given range or set. This helps to establish the validity of a mathematical argument or problem solution.
What is the process for completing an inequality proof?
The process for completing an inequality proof involves identifying the statement or equation to be proven, breaking it down into simpler parts, applying mathematical rules and principles to manipulate the equation, and providing a logical explanation for each step of the proof.
What are some common techniques used in inequality proofs?
Some common techniques used in inequality proofs include algebraic manipulation, substitution, factoring, and the use of mathematical properties such as the distributive property and the triangle inequality.
Why is understanding "Inequality proof (Spivak 1.6-b)" important in the field of science?
Understanding "Inequality proof (Spivak 1.6-b)" is important in the field of science because it allows scientists to make accurate and precise mathematical arguments and support their hypotheses and theories. It also helps in analyzing and interpreting data and making predictions based on mathematical models.
