Installing a motion lightconfused about wiring don't wanna burn the house down
In summary: R's are unavailable to help with this issue. Neither the company's technical support line nor the company's customer service are available during the hours you are away.This is because the company is closed.In summary, the dual light does not work and it is possible that it could cause a fire while you are away. You should have an electrical schematic included with your light and should consult with an electrician if the wiring is not correct.
thyssen
Heath/Zenith DualBrite Motion Sensor Light
can't call company's tech support because they are closed and I'm going out of town in 8 hours and don't want to come back to a pile of ash where my house use to be.
When installing the light , I'm suppose to connect single provided black to black and single provided white to white but when i took off the "old" dual light there was only red, pink, and white. Also on the old light there were 2 black wires leading from each lightbulb to.. (one to the red wire and one to the pink wire) and then white to white. Am i suppose to connect the black wire on the new light to both the red and pink (all 3 tied together under a cover)? OR am i suppose to connect the black wire to the red wire and then just cover the pink wire and leave it alone? Will it get hot and cause a fire because the power running through it has nowhere to go? Does it work that way? I already installed the light and i connected the single provided black wire from the new light to the red wire in the circuit box and the single provided white to white and left the pink alone covered with one of those screw on rubber electric covers. .. and the think works perfectly . but will that one pink wire overheat and start a fire while I'm gone?
Welcome to PF.
Chances are you will find that you have a light switch that no longer does anything.
Doing what you did is much preferable to hooking the red, pink, and black together.
That could have caused a few blown fuses.
A disconnected wire properly covered is not a problem.
However, red, pink and white is an unusual configuration.
Since you don't know why it was done that way, I would recommend that you hire an electrician to check your work.
The current drawn from bare wires is inversely proportional to the impedence of the consumer.
Black Wire to source power (house), White Wire to White Neutral all Neutrals together, and the Red Wire to the Load (lamp) or other.
Placing a S.P. Switch in line with the source and before the detector will give you control to turn it OFF or to LOCK it on.
DO NOT forget connect all grounds for safety.
You should have an electrical schematic included with your light on how to connect it. If not, hire an electrician. If it was included, scan it and post it.
However, like NoTime mentioned, if you hook it up wrong it should just trip the breaker or perhaps blowing a fuse (assuming who ever wired your house did it correctly).
CS
FAQ: Installing a motion lightconfused about wiring don't wanna burn the house down
How do I properly wire a motion light?
To properly wire a motion light, you will need to turn off the power to the area where you will be installing the light. Then, carefully follow the instructions provided by the manufacturer. Generally, you will need to connect the black wire from the light to the black wire from the electrical box, and the white wire from the light to the white wire from the electrical box. The green or copper wire should be connected to the ground wire. If you are unsure, it is best to consult a licensed electrician for assistance.
What do I do if I am confused about the wiring for my motion light?
If you are confused about the wiring for your motion light, it is best to stop and seek help. Trying to wire the light incorrectly can be dangerous and may result in damage to your home. You can consult the manufacturer's instructions, or hire a licensed electrician to ensure the wiring is done correctly.
Can I install a motion light without any prior electrical experience?
It is not recommended to install a motion light without any prior electrical experience. Electricity can be dangerous and it is important to have a basic understanding of how to safely handle and connect wires. If you are unsure, it is best to hire a licensed electrician to install the motion light for you.
How do I make sure I don't burn down my house while installing a motion light?
To prevent the risk of fire, it is important to turn off the power to the area where you will be installing the motion light. Additionally, make sure to carefully follow the manufacturer's instructions for proper wiring. If you are unsure, it is best to seek the help of a licensed electrician.
Do I need any special tools to install a motion light?
Most motion lights come with all the necessary hardware and tools for installation. However, you may need a ladder, screwdriver, wire strippers, and wire nuts. It is important to have the right tools for the job to ensure the installation is done correctly and safely.
