Integration by parts and characteristic functions
In summary: I appreciate the clarification and explanation. In summary, integration by parts formula states that when given characteristic functions f and g on the intervals [1,4] and [2,5] respectively, with derivatives existing almost everywhere, and applying the formula \intf(x)g'(x)dx=f(3)g(3)-f(0)g(0)-\intf'(x)g(x)dx, both integrals are 0 but f(3)g(3)-f(0)g(0) is equal to 1 due to the discontinuity between 0 and 1 for both functions. However, this formula cannot be generalized to discontinuous functions unless using more advanced ideas such as distribution theory.
raw
36
Given characteristic functions f and g on the intervals [1,4] and [2,5] respectively. The derivatives of f and g exist almost everywhere. The integration by parts formula says [tex]\int[/tex]f(x)g'(x)dx=f(3)g(3)-f(0)g(0)-[tex]\int[/tex]f'(x)g(x)dx. Both integrals are 0 but f(3)g(3)-f(0)g(0) is equal to 1. Why is this?
Characteristic functions equal 1 on the interval given and 0 everywhere.
I'm really not sure. Does it have anything to do with the discontinuity between 0 and for both functions? I'm really bad at these types of questions...
To apply the integration by parts formula, then we need the function to be differentiable everywhere...
There does exist a generalization of the formula where differentiability is not necessary, but we still require the functions to be continuous everywhere. Your example shows that we cannot generalize the "integration by parts"-formula to discontinuous functions...
micromass's explanation is the correct one for basic analysis. However, it is possible to make integration by parts make sense for very rough functions using more advanced ideas which go by the name of "distribution theory". WARNING: although distribution theory is perfectly rigorous mathematics, the explanation below is anything but, so is probably not useful to you except for talking to physicists.
There is a thing which physicists call a "delta function", and we mathematicians also denote by [tex]\delta[/tex] but insist on reminding everyone that it isn't actually a function in the conventional sense. Informally (physicist time), imagine that [tex]\delta(x)[/tex] is a function which is zero everywhere except at [tex]x = 0[/tex], where it is infinite. But it's "exactly the right size of infinity" so that when you multiply it by something else and integrate, it pulls out the value at that point: [tex]\int_{-\infty}^\infty \delta(x) f(x)\,dx = f(0)[/tex].
In your setup, what happens that makes integration by parts work is that you realize we should put [tex]f'(x) = \delta(x - 1) - \delta(x - 4)[/tex], [tex]g'(x) = \delta(x - 2) - \delta(x - 5)[/tex]: that is, the derivative of [tex]f[/tex] is a positive "unit spike" at 1, a negative "unit spike" at 4, and zero everywhere else. Makes sense, right?
Then you wind up with [tex]\int_0^3 f(x) g'(x)\,dx = f(2) = 1[/tex], [tex]\int_0^3 f'(x) g(x) \,dx = g(1) = 0[/tex], and both sides of your equation are 1, just as you want.
Thank you both for your quick and helpful replies.
FAQ: Integration by parts and characteristic functions
What is integration by parts?
Integration by parts is a method in calculus used to evaluate integrals of products of functions. It is based on the product rule of differentiation and involves choosing one function to be differentiated and another to be integrated.
How is integration by parts used?
Integration by parts is used to simplify integrals that are difficult or impossible to solve using other methods. It is also used to solve various types of differential equations and in applications such as physics and engineering.
What are the steps for using integration by parts?
The basic steps for using integration by parts are:
  • Identify the two functions in the integral to be integrated and differentiated
  • Choose one function to be differentiated and the other to be integrated
  • Apply the integration by parts formula: ∫u dv = uv - ∫v du
  • Solve the new integral on the right-hand side, and if needed, repeat the process until the integral is fully solved
What are characteristic functions?
Characteristic functions are mathematical functions that are used to describe the probability distribution of a random variable. They are typically defined as the expected value of a random variable raised to a complex power.
How are characteristic functions used in probability and statistics?
Characteristic functions are used in probability and statistics to describe the properties of random variables, such as their mean, variance, and moments. They are also used to prove theorems and derive formulas related to probability distributions.
