Integration by parts and infinity
In summary, the homework statement is to integrate (x*2e^x)/(2e^x-1)2 from x=0 to infinity. The Attempt at a Solution starts with letting t=2e^x-1 and then integrate (ln((t+1)/2))/t^2 dt from t=1 to infinity. This leads to an equation that integrate 2lnu/(2u-1)^2 from u=1 to infinity. However, the Attempt at a Solution goes around in a circle because the second integral is indeterminate. Integrating (2u-1)-2 and differentiating lnu in the second integral, the student gets ln
kwy
let t=2e^x-1 => x=ln((t+1)/2)
dt = 2e^x dx
Thus equation is now integrate (ln((t+1)/2))/t^2 dt from t=1 to infinity
Then let u = (t+1)/2 => 2du=dt
Equation now integrate 2lnu/(2u-1)^2 from u=1 to infinity
Then I started going around in circle...
2lnu/(2u-1)^2
Integrate (2u-1)-2 and differentiate lnu in the second integral,writing along with the first integral(the usual way you integrate by parts).Then apply partial fractions in the second in the second integral.I got ln2 as answer.
Thanks aim1732, but I'm still a little off.
diff lnu = 1/u, int (2u-1)^-2 = -1/2(2u-1)
Thus equation is now:
1) 2([-lnu/2(2u-1)] u=infinity to 1 + int(1/u)du + int(1/4u-2)du)
2) 2( 0 + int(1/u)du + int(1/4u-2)du)
3) 2([-1/u^2] + [ln(4u-2)]) where u=1 to infinity
4) 2[0-(-1)) + infinity - ln(2)]
5) 2(1 + infinity - ln(2))
Sorry for spelling out all the lines, I'm really rusty at this.
Can you please let me know where I've gone wrong?
Thanks for your assistance.
Sorry i can not understand what you wrote.It's okay I think you are aware that putting the limits for the integral involves calculating the LHL for the upper limit and RHL for the lower one.I had to use L'Hospitals rule once.Remember all you have to do is eliminate the indeterminate forms.
If you still have problems i am going to take a hard look at your work then I guess.
Sorry, I'm going to try using LaTex to see if it makes more sense. If the lines below does not make sense, I apologise. Would you mind letting me know where you had to use L'Hopital Rule, I cannot work out where this can be applied:
My previous workings were:
2(0 + [tex]\int 1/u * 1/4u-2 du[/tex])
2([tex]\int 1/u du[/tex] + [tex]\int 1/(4u-2) du[/tex]), with integration from 1 to infinity
I get:
[tex]\int 1/u du[/tex] = 1
[tex]\int 1/(4u-2) du[/tex] = infinity-ln(2)
Putting them together: 2(1 + infinity + ln2)
Trick is in clubbing the the log terms together.
The integral as I see it is this:
ln(2u-1) - lnu -(lnu)/2u-1
This you can write as
ln[(2u-1)/u] - lnu/(2u-1)
ie. ln(2-(1/u)) - lnu/(2u-1)
Now put the limits.Notice the second term is of the form ∞/∞ for the upper limit so apply L'hospitals.
Hi aim1732
Thank you for your help. It was very rude of me to leave it so late.
The assignment has already been marked, and that question was not even included in the marking (only half of the questions are randomly chosen for marking).
Thanks again.
Cheers
kwy
FAQ: Integration by parts and infinity
What is integration by parts and how is it used?
Integration by parts is a method used in calculus to evaluate integrals that are in the form of a product of two functions. It involves using the product rule from differentiation to simplify the integral into a form that is easier to solve.
Can integration by parts be used to solve integrals involving infinity?
Yes, integration by parts can be used to solve integrals involving infinity as long as the limits are well-defined and the functions involved satisfy certain conditions.
What is the concept of "infinity" in integration by parts?
Infinity in integration by parts refers to the limits of integration, which can be either finite or infinite. When dealing with infinite limits, it is important to consider the behavior of the functions involved at these limits to ensure the integral is convergent.
How do you determine which function to differentiate and which to integrate in integration by parts?
The standard formula for integration by parts is ∫u dv = uv - ∫v du, where u and v are the two functions involved. To determine which function to differentiate and which to integrate, you can use the acronym "LIATE": logarithmic, inverse trigonometric, algebraic, trigonometric, exponential. The function that comes first in this list should be differentiated, while the one that comes later should be integrated.
Are there any limitations to using integration by parts?
Integration by parts has limitations in that it can only be used to solve certain types of integrals, specifically those that can be written in the form of a product of two functions. It also does not work for all functions and may not always result in a solution.
