Integration of functions: problem with borders
So, using your notation, you really want to calculate\lim_{A\to \frac{\pi}{4}} \lim_{B\to \frac{3\pi}{4}} \int_A^B \tan(2x)~dxwhich is the same as,\lim_{A\to \frac{\pi}{4}} \lim_{B\to \frac{3\pi}{4}} \lim_{C\to A}\lim_{D\to B} \int_C^D \tan(2x)~dxNow, if you make the change of variables u=2x, dv=dx then,\int \tan(2x)dx = \frac12
Gamma
357
I have couple of problems that I am stuck with.
Hi,
Integration (tan(2x) dx limit pi/4 to 3 pi/4
When I intergrate this, I get ln [1/(sqrt(cos2x))]
So when put the limits, we have zero in the denominator. What do I do?
The other problem is,
integration (1/(t-3) dt limit t to 3
With this one the problem is we have ln (0). What is the value of ln(0)?
Thannks fo r any help
Hi,
I think you made a slight mistake there. Instead of getting
[tex]ln (cos 2x)^{-(1/2)}}[/tex]
you should have gotten:
[tex]-\frac{1}{2} ln (cos 2x)[/tex]
Or at least you should have realized the first is actually the same as the second.
By the way, you really didn't even have to finish integrating to find out the answer was zero. If you use u-substitution and change your limits of integration, you never have to substitute the original function back in. In other words:
[tex]u=cos 2x \vert_{\frac{\pi}{4}=0}^{\frac{3 \pi}{4}=0}[/tex]
Since your new lower and upper bounds are equal to each other, you know your result will be zero. If you did continue, you would get to:
[tex]du=-2 sin 2x dx[/tex]
[tex]-\frac{1}{2} du = sin 2x dx[/tex]
Substituting back into your original equation,
[tex]-\frac{1}{2} \int_{0}^{0} \frac{1}{u} du[/tex]
[tex]-\frac{1}{2} ln u \vert_{0}^{0}[/tex]
Thank you,
I understand your point.
But there is nothing wrong in writing
[tex]-\frac{1}{2} ln (cos 2x) = ln (cos 2x)^{-(1/2)}[/tex]right?
By the way is ln(0) defined?
Gamma said:
Thank you,
right?
Technically, no.:redface: I was thinking there had to be a way to avoid the problem, since I know the answer is 0. You just have to rely on the idea that the upper limit and lower limit are the same.
The answer to your last question, "is ln(0) define" is "no". ln(x) is defined only for positive real numbers. (If you extend to complex numbers, ln(x) is defined for for negative x but still not for 0.)
The limit if ln(x), as x goes to 0, is negative infinity.
Be very careful with your first question. When you have an integral that is 'improper' at both endpoints you have to allow your limits to approach these endpoints independantly (unless you are explicitly talking about a Cauchy Principle Value).
FAQ: Integration of functions: problem with borders
What is integration of functions?
Integration of functions is a mathematical process that involves finding the area under the curve of a given function. It is the inverse operation of differentiation, and it helps in solving various problems in physics, engineering, and other fields.
What is the purpose of integration?
The main purpose of integration is to find the total or net change in a quantity. It is also used to find the area, volume, and other important parameters in various real-world problems.
What are the different methods of integration?
The most commonly used methods of integration are the substitution method, integration by parts, partial fractions, and trigonometric substitution. Each method is used depending on the complexity of the function and the problem at hand.
What is the meaning of "problem with borders" in integration?
"Problem with borders" in integration refers to the integration of functions that have definite limits or borders. These limits define the range over which the integration is to be performed, and they can be numbers, variables, or functions.
How do you solve an integration problem with borders?
To solve an integration problem with borders, you need to first identify the type of function and choose the appropriate method of integration. Then, you can substitute the given limits into the final integrated equation and solve for the result. It is important to double check your answer and make sure it satisfies the given limits.
