soothsayer
- 423
- 5
I had a couple questions regarding the ability of objects and light to escape a black hole.
1) The even horizon is supposedly the boundary at which no object can escape from a Black Hole, as within this radius, the escape velocity is greater than c. This much I understand; If I throw myself into a black hole with a flashlight and shine that flashlight outward from the black hole after I cross the event horizon, that light will not escape from the black hole. However, if you enter into the black hole with a very high powered spaceship and cross the event horizon, I feel like all you would need to do would be to fire the ships rockets with enough force to slightly overcome the force of gravity from the black hole and you can slowly accelerate out of the black hole, a simple force diagram would suggest this. Is this not the case? And if so, isn't it a bit misleading to say NOTHING can escape from a black hole once it's past the event horizon? The escape velocity would be the minimum velocity an object must have to escape a gravity well given there is no added propulsion, correct?
2) I'm a bit confused as to what happens to light that is trapped in a black hole. GR tells us that light that is trying to escape from the surface of a massive object is subject to redshift, as gravity will apply a force to that light and thus, do work on it, lowering the energy of the photons. Take the above example, where I foolishly launch myself into a black hole with a flashlight. I cross the event horizon and turn the flashlight on and the photons can't move fast enough to escape the black hole. The red shifted frequency, relative to a far away observer, would approach zero as the beam approached the event horizon. What does this mean physically for the photons in the light beam, do they reach some point in the gravity well, slow to a stop and fall back down, like a ball thrown upward from Earth? Can the photons ever even be slowed below c in a vacuum? I don't understand what it means to say the photon energy and frequency is zero.
Any insight would be greatly appreciated! =)
