- #36
Nugatory
Mentor
- 15,164
- 9,990
Ahhh... How do you think the light of distant stars makes it to your eyes, if that light did not propagate through the empty space between star and earth? Electrical and magnetic fields can exist in a vacuum, in air, or in any other matter, and where the fields exist there can be waves in them.Heretoignore said:Astronauts are not ''blind'' in space, in space there is no air. It is not so obvious that light propagates in space
We don't. We do know that the laws of electricity and magnetism, which were formalized in Maxwell's equations more than 150 years ago, say that there will be waves in the electrical and magnetic fields even when nothing is interacting with the propagating waves. We do know that centuries of observations of the behavior of light agree with the answers we get when we calculate what would happen if light is in fact a wave as described by these laws of electricity and magnetism. We do know that no one has ever been able to come up with any alternative that correctly describes the observed behavior of light. Putting all that together... The only sensible theory we have says that light is a wave in the electrical and magnetic fields and all the available evidence supports this explanation. That's as good as it ever gets in science.How do we know it is not only a wave when light is being interfered with?
You construct a light source that generates electromagnetic radiation with an appropriate mixture of frequencies, activate it, and see if the light that comes out is white. It is. Then you suppress some of the frequencies to get a different mixture, see if the light is still white. It isn't. That doesn't prove that white light is a mixture of frequencies, but it does support that hypothesis and it shifts the burden of proof to people who claim that they have some plausible alternative explanation.How do we know that '''white light'' is really a mixture of frequencies?
Can we use that model to correctly calculate the deflection of light of different colors (don't forget the stuff outside the visible spectrum, from radio waves to hard x-rays) when it encounters materials of different composition? And that agrees with all the other observations of light that we've been able to make over the centuries? The wave theory does all those things, and a lot more besides. For example...Could a prism simply not just be a result of a Center of pressure (C.O.M), offset, the angular displacement of the prisms surface having effect on the radiation pressures force by angular distance travelled?
Set up the wave equation for waves of various frequencies intersecting an angled surface, solve it, see you get. If you do the calculation right, you'll get a result that says the waves of different frequencies are deflected by different angles. Now check those calculated results against the behavior of a real prism. The results will agree to within the limits of your measurement accuracy.What mechanism would a prism have to separate a mixture of incident frequencies to from individual outputs of a wavelength?
The real takeaway here should be that is pretty much impossible to replace (or even improve) a theory before you understand what it does.
