Is r in the Moment of Inertia Formula Always the Shortest Distance?
In summary, the term "mr^2" refers to the moment of inertia for a single particle, but if you have a square of point masses in the corners, you must consider each point mass individually. If the rods have evenly distributed mass, you must integrate the moment of inertia along the length of the rod to get it for the whole rod. However, you can also look up the moment of inertia for different shapes and mass distributions in handbooks and add them together.
jono90one
28
for "r" in mr^2 is it the shortest distance?
(consider a square with point mass at the corners connected by rods, r is closer if you take the diagonal height rather than the rod distance.)
Can you give us the context in which this was stated?
In general, the term mr2 refers to the mass and distance from a reference axis of a single particle (i.e. a point-like mass distribution). If you have a square of point masses in the corners, you have to consider each point mass as contributing to the moment of inertia by that term. If your rods have mass that is, say, evenly distributed along their length, you have, in principle, to integrate moment of inertia r2dm along the length of the rod (with varying r) in order to get it for the whole rod. See for instance [1] for an introduction.
In practice you can look up the moment of inertia for many geometrical shapes and mass distributions in handbooks, transform those moments to a common reference axis and then add them. Or you let your CAD system do it for you.
[1] http://en.wikipedia.org/wiki/Quantum_entanglement
FAQ: Is r in the Moment of Inertia Formula Always the Shortest Distance?
What is moment of inertia?
Moment of inertia is a measure of an object's resistance to changes in its rotational motion. It is often referred to as the rotational equivalent of mass.
How is moment of inertia calculated?
The moment of inertia of an object can be calculated by multiplying the mass of the object by the square of its distance from the axis of rotation. The formula is I = mr², where I is the moment of inertia, m is the mass, and r is the distance from the axis of rotation.
What are some real-life examples of moment of inertia?
Some common examples of moment of inertia include a spinning top, a swinging pendulum, and a rotating wheel. In each of these cases, the moment of inertia plays a crucial role in determining the object's motion.
How does moment of inertia affect an object's rotational motion?
The moment of inertia determines how much torque is required to change an object's rotational motion. Objects with a larger moment of inertia will require more torque to change their rotational speed, while objects with a smaller moment of inertia will require less torque.
Can the moment of inertia of an object be changed?
Yes, the moment of inertia of an object can be changed by altering its mass distribution or changing the axis of rotation. For example, a figure skater can change their moment of inertia by bringing their arms closer to their body, causing them to spin faster.
