Is the direction of electric field the direction of current?
In summary: Ok ... I'll put the tensor idea, on the back burner.In summary, the direction of electric field and the direction of conventional current are not always the same. However, in the special case of a current inside a conductive material, they are proportional to each other and follow the same direction. This is known as Ohm's law. In anisotropic materials, the resistivity is described by a tensor and the current density may not be in the same direction as the electric field. However, this is a more advanced topic and may not be relevant to the OP's question.
StevenJacobs990
Is the direction of electric field save as the direction of (conventional) current?
no, it's in the direction of charge flow ... electron direction. It is the electric field that drives the motion of the electrons/charge
@davenn is correct. In general the electric field and the current are not in the same direction.
However, in the special case of a current inside a conductive material the direction of the current and the direction of the E field are the same and they are proportional to each other. This is the meaning of Ohm's law
Likes cnh1995
Careful here. Th direction of Positive charge is defined by the direction of the field. That is the direction of the conventional current. Signs need to be observed meticulously and that post doesn't make it as clear as it should. Anyone who is struggling will need to make a conscious effort to realize minus times minus is plus when doing the sums.
Is the direction of electric field same as the direction of (conventional) current?
I would say that is perfectly correct and that bringing electrons in is not relevant here. The sign of the particles carrying the current is something that comes in much later.
I don't get this. Positive charges will flow from a positive plate to a negative plate. That is also direction of the Field, isn't it? It may be that electrons are carrying the charge but that doesn't affect the conventional current.
Did you have something else in mind? I'm sure you must have.
I was thinking of free charges in vacuum, where you can have currents (charge velocity) without an E field (charge acceleration).
That's a relief! :smile:
But I'm reading the OP and assuming it is a question about the everyday situations of circuits, currents, devices and PD, In any of those situations, charge will flow (or at least be displaced) in the direction of any net Electric field.
I think it's time to give the OP a chance to respond and give us a better clue about the level of his question.
jtbell said:
There are anisotropic materials (e.g. graphite) in which the resistivity is described by a tensor, and the current density at a point is not necessarily in the same direction as the electric field.
https://en.wikipedia.org/wiki/Elect...ty#Tensor_equations_for_anisotropic_materials
This is a rather advanced topic, though. I don't remember seeing it in an introductory textbook.
Yes. It's a scientific truth but does it help with the OP's question? Seasoned PF members don't always take not of the Code Letter, associated with the title. It's a B, in this case, meaning basic High School Level.
FAQ: Is the direction of electric field the direction of current?
Is the direction of electric field the same as the direction of current?
No, the direction of electric field is not necessarily the same as the direction of current. Electric fields are created by the movement of charged particles, while electric currents are the flow of these charged particles.
How does the direction of electric field relate to the direction of current?
The direction of electric field and current are related by the right-hand rule. If the electric field is pointing in a certain direction, the current will flow in the direction perpendicular to the electric field.
Can electric current flow in the opposite direction of the electric field?
Yes, electric current can flow in the opposite direction of the electric field. This can occur in situations where the movement of charged particles is influenced by other factors, such as the presence of a magnetic field.
Is the direction of electric field always constant?
No, the direction of electric field can change depending on the location and strength of the source of the electric field. It can also be influenced by other factors such as the presence of other charged particles or magnetic fields.
Why is it important to understand the relationship between electric field and current direction?
It is important to understand the relationship between electric field and current direction in order to accurately predict and control the behavior of electrical systems. This knowledge is crucial in fields such as electronics, power engineering, and telecommunications.
