Is the momentum conservation law correct in parametric conversion process?
In summary, the efficiency of optical parametric conversion is determined by the function sinc(ΔkL), where L is the length of the crystal and Δk is the phase mismatch condition. When Δk=0, the conversion efficiency is at its maximum, known as the momentum conservation law. However, even when Δk≠0, the process can still occur, indicating a possible involvement of Raman scattering where momentum is exchanged with the lattice. There is also a question about how momentum is exchanged in the absence of a virtual level and with no change in total energy. Additionally, when a photon enters a medium with a refractive index greater than 1, its momentum changes and then recovers upon exiting to vacuum. The mechanism
Torero
In optical parametric conversion process, such as second harmonic generation,the conversion efficient is determined by function sinc(ΔkL),where L is the length of the crystal,and Δk is the phase mismatch condition. When the sum of wave vectors of the two fundamental photon,equals to that of the second harmonic photon, that is Δk=0, the conversion efficient is maximum.That is the usually called momentum conservation law of parametric conversion.But here comes the question,when Δk≠0,this process can still take place.Then momentum of the fundamental photons and second harmonic photons won`t conserve.
I would guess that something like Raman scattering is involved here, i.e. momentum is exchanged with the lattice.
thank you.yes,maybe there is something we miss.In the parametric process,there is no virtual level involved,and total energy of photons never change. how could momentum exchanged?
also there is another question, consider a photon incident into a medium,such as quartz, from vacuum, its momentum changes for the refractive index of the medium is larger than 1.
When it exit to the vacuum again, its momentum recovers. i just can not imaging how the momentum exchanges.
Related to Is the momentum conservation law correct in parametric conversion process?
1. What is the momentum conservation law?
The momentum conservation law states that within a closed system, the total momentum of all objects remains constant unless acted upon by an external force.
2. How does the momentum conservation law apply to parametric conversion processes?
In parametric conversion processes, energy is transferred between different forms (such as heat, light, or electricity). The momentum conservation law still applies, as the total momentum of the system must remain constant even as energy is converted and transferred.
3. Is the momentum conservation law always correct in parametric conversion processes?
Yes, the momentum conservation law is a fundamental principle of physics and applies to all physical processes, including parametric conversion. However, in certain cases, it may appear that momentum is not conserved due to external forces or limitations in measurement accuracy.
4. How is the momentum conservation law verified in parametric conversion processes?
The momentum conservation law can be verified through experimental observations and mathematical calculations. In parametric conversion processes, the momentum of the initial and final states can be measured and compared to ensure that the total momentum remains constant.
5. What are the implications of the momentum conservation law in parametric conversion processes?
The momentum conservation law plays a crucial role in understanding and predicting the behavior of physical systems. In parametric conversion processes, it ensures that energy is conserved and that the resulting changes in momentum are accurately accounted for.
