Is the Sturm-Liouville Operator Symmetric in Inner Product Spaces?
  • MHB
  • Thread starter Poirot1
  • Tags
    Operator
In summary, the Sturm-Liouville operator is a symmetric operator with respect to a generalized inner product in a function space. This inner product can be defined as an integral with a complex conjugate and a weight function. To show symmetry, one must use integration by parts and account for the boundary conditions. The concept of the weight function is important in understanding the Sturm-Liouville operator.
Poirot1
245
What does it mean for Sturm-Liouville operator to be symmetric w.r.t an inner product?
I was reading in a book that it is symmetric but that was about a certain integral being zero and inner products had not even been mentioned.
You have to generalize the concept of "inner product". In normal 3D-space, it's called the dot product:
$$\langle \vec{x}|\vec{y}\rangle=\vec{x}\cdot\vec{y}=\sum_{j=1}^{3}x_{j}y_{j}.$$
But there are other "spaces" out there: metric spaces, normed spaces, inner product spaces, Banach spaces, Hilbert spaces, Sobolev spaces. They each have different axioms with which you start. The inner product space is fairly general, and the "vectors" can be the usual vectors in 3D space, or they could be functions in a function space. The usual inner product defined in a function space is
$$\langle f|g\rangle:=\int_{A} \overline{f} \,g\,d\mu.$$
Here $\overline{f}$ indicates the complex conjugate of $f$, and the $d\mu$ indicates that we've defined this integral to be a Lebesgue integral. $A$ is the set over which the function space is defined.
Now we have the background to answer your question. A Sturm-Liouville operator
$$L=\frac{1}{w(x)}\left(-\frac{d}{dx}\left[p(x)\,\frac{d}{dx}\right]+q(x)\right)$$
is symmetric (more properly, Hermitian) w.r.t. the inner product
$$\langle f|g\rangle:=\int_{A}\overline{f}\,g\,w(x)\,d\mu,$$
if and only if for every $f, g$ in the inner product space, it is true that
$$\langle Lf|g\rangle=\langle f|Lg\rangle.$$
With the Sturm-Liouville operator, you need to show that
$$\int_{A}\overline{\left\{\frac{1}{w(x)}\left(-\frac{d}{dx}\left[p(x)\,\frac{df}{dx}\right]+q(x)f\right)\right\}}\,g\,w(x)\,d\mu=\int_{A} \overline{f} \left\{\frac{1}{w(x)}\left(-\frac{d}{dx}\left[p(x)\,\frac{dg}{dx}\right]+q(x)g\right)\right\}\,w(x)\,d\mu.$$
You can do this using simple integration by parts twice. The boundary terms vanish because of the conditions on them. (Note that the boundary conditions are considered to be part of the operator.)
I note you marked this thread as solved. That is good. Perhaps this post will throw in a few helpful concepts.
Sorry you took your time. I should perhaps do a bit more reasearch before asking here.
No, that's all right. Incidentally, there are some concepts here that might help you with your other problem. Take a look at how $w(x)$ appears in the Sturm-Liouville operator, as well as how it shows up in the inner product w.r.t. which the Sturm-Liouville operator is symmetric.
The Sturm-Liouville operator is a mathematical operator that is commonly used in the study of differential equations and boundary value problems. It is defined as a second-order differential operator that involves a variable coefficient and a weight function.
When we say that the Sturm-Liouville operator is symmetric with respect to an inner product, it means that the operator satisfies a specific symmetry property when applied to functions in the inner product space. This property is known as self-adjointness and is closely related to the concept of symmetry.
In simpler terms, if we have two functions f(x) and g(x) in the inner product space, the Sturm-Liouville operator being symmetric means that the inner product of the operator applied to f(x) and g(x) is equal to the inner product of g(x) and the operator applied to f(x). This is similar to the concept of mirror symmetry, where the reflection of an object is identical to the original.
The significance of this property is that it allows us to use powerful mathematical tools, such as the spectral theorem, to study the properties of the Sturm-Liouville operator and its associated differential equations. It also allows us to make important conclusions about the eigenvalues and eigenfunctions of the operator, which have important applications in physics and engineering.
In summary, the symmetry of the Sturm-Liouville operator with respect to an inner product is a fundamental property that plays a crucial role in the analysis of differential equations and boundary value problems.
FAQ: Is the Sturm-Liouville Operator Symmetric in Inner Product Spaces?
What is a Sturm-Liouville operator?
A Sturm-Liouville operator is a linear differential operator that is commonly used in the study of partial differential equations. It is named after mathematicians Jacques Charles François Sturm and Joseph Liouville, who independently developed the concept in the 19th century.
What are the key properties of a Sturm-Liouville operator?
The key properties of a Sturm-Liouville operator include self-adjointness, orthogonality, and completeness. These properties make it a powerful tool for solving differential equations and studying the properties of eigenfunctions and eigenvalues.
How is a Sturm-Liouville operator used in physics?
A Sturm-Liouville operator is commonly used in physics to study systems that exhibit oscillatory behavior, such as vibrating strings, membranes, and quantum mechanical systems. It allows for the determination of natural frequencies and mode shapes of these systems.
What is the significance of the eigenfunctions and eigenvalues of a Sturm-Liouville operator?
The eigenfunctions and eigenvalues of a Sturm-Liouville operator play a crucial role in solving differential equations and understanding the behavior of physical systems. They represent the fundamental modes of oscillation in a system and can be used to express any solution to a differential equation as a linear combination of these modes.
Are there real-world applications of the Sturm-Liouville operator?
Yes, there are many real-world applications of the Sturm-Liouville operator. In addition to its use in physics, it is also used in engineering, particularly in the design of structures and systems that exhibit oscillatory behavior. It has also been applied in fields such as acoustics, electromagnetics, and signal processing.
