Isomorphism and Binary operation
In summary: It does! And yes, "they" can sound awkward at times, but it is a useful pronoun when the gender is unknown or irrelevant.
Gale
684
(i) If [itex](X,*) [/itex] is a binary operation, show that the identity function
[itex] Id_X : X \rightarrow X [/itex]is an isomorphism.
(ii) Let [itex](X_1, *_1) and (X_2, *_2)[/itex] be two binary structures and let [itex]f : X_1 \rightarrow X_2[/itex] be an isomorphism of the binary structures. Show that [itex]f^-1 : X_2 \rightarrow X_1 [/itex] is also an isomorphism.
(iii) Let [itex] (X_1, *_1), (X_2, *_2), (X_3, *_3) [/itex] be three binary structures and
let [itex] f : X_1 \rightarrow X_2 [/itex] and [itex] g : X_2 \rightarrow X_3 [/itex] be isomorphisms of the binary structures. Show that [itex] g \circ f : X_1 \rightarrow X_3 [/itex] is also an isomorphism.
(iv) Denote the statement that [itex](X_1,*_1) [/itex] and [itex] (X_2, *_2) [/itex]are isomorphic by [itex](X_1, *_1) \cong (X_2, *_2)[/itex]. Using the above, show that [itex] \cong[/itex] is reflexive, symmetric and transitive.
Okay, so I'm a bit confused with how to work with isomorphisms and binary operations in general. I'm don't know how to approach the first half of the problem, so I can't really do the rest either. Am I supposed to choose elements from the set X and work my proofs from there, or is there some other approach I should be taking? Besides that, I'm not sure I entirely understand the more general premise of the problems:
Starting with i) I'm not sure why the identity function is only isomorphic when there exists a binary relation. I'm not very confident in my understanding, but it seems like the identity function would always be isomorphic?
ii) I'm not sure how to start a proof for this, but since f is an isomorphism, isn't it necessarily bijective so obviously it would have an inverse? I'm confused as to what the proof is supposed to prove?
the definition of an isomorphism is that the function is bijective and linear. I think the first question pertains to the identical function, which does not (?) make use of * .
This is why I don't understand the problem... I think. The identity function isn't ismorphic with itself, because its only operating on the set X, and isomorphisms are from functions to functions? But I suppose the question could be relating the Id function to the initial binary operation? But if that's the case, I'm still not sure where to start the proof for that...
Okay, so I've been trying to figure out part i, does this make sense:
If [itex] Id_x[/itex] is isomorphic then [itex] Id_x (x_1 * x_2)= Id_x(x_1)* Id_x(x_2)[/itex]
[tex] Id_x(x_1 * x_2)= x_1 * x_2; Id_x (x_1)= x_1, Id_x(x_2)= x_2 \Rightarrow Id_x(x_1) * Id_x(x_2)= x_1 *x_2= Id_x(x_1*x_2)[/tex]
Therefore [itex] Id_x[/itex] is isomorphic?
For part ii) I was trying to use a similar argument, but I'm not sure it works. Is there a different way to approach it?
That is correct.
Part (ii) is a bit tricky. You'll need to prove that for [itex]y_1,y_2\in X_2[/itex], that [itex]f^{-1}(y_1*y_2)=f^{-1}(y_1)*f^{-1}(y_2)[/itex]. What does [itex]f^{-1}(y_1),~f^{-1}(y_2),~f^{-1}(y_1*y_2)[/itex] mean by definition?
micromass said:
That is correct.
Technically he just showed [itex]Id_{x}[/itex] is a homomorphism, no? To complete showing that it is an isomorphism, he'd have to show that [itex]Id_{x}[/itex] is also bijective, granted that follows rather trivially from the definition of the identity function, but I think he should still state something like "And [itex]Id_{s}[/itex] is bijective by definition" after that bit.
Yes, you are correct! It should have been added.
Thanks... someone else noticed that today as well. I suppose I wasn't solid on the definition of an isomorphism... so I didn't realize I needed a bijection. We haven't spent any time discussing other morphisms, so I didn't understand the difference.
(Also, I'm a she, not he)
English needs a pronoun for when one does not know gender xD. Using "they" sounds so awkward when referring to one person!
Related to Isomorphism and Binary operation
1. What is isomorphism?
Isomorphism is a mathematical concept that describes a one-to-one correspondence between two mathematical structures. It means that the structures have the same underlying structure and can be mapped onto each other without losing any important information.
2. What is a binary operation?
A binary operation is a mathematical operation that takes two elements from a set and produces a single element from that same set. Examples of binary operations include addition, multiplication, and composition of functions.
3. How is isomorphism related to binary operations?
Isomorphism can be used to compare and classify binary operations. If two structures have the same binary operation, they can be considered isomorphic and have the same properties. Isomorphic structures also have the same number of elements and the same types of elements.
4. What is the importance of isomorphism and binary operations in mathematics?
Isomorphism and binary operations are important concepts in mathematics because they allow us to compare and classify mathematical structures. They also help us understand the relationship between different structures and how they can be transformed or manipulated.
5. What are some real-world applications of isomorphism and binary operations?
Isomorphism and binary operations have many applications in fields such as computer science, physics, and chemistry. In computer science, they are used in data structures and algorithms. In physics, they are used to describe symmetry and conservation laws. In chemistry, they are used to understand the properties of molecules and chemical reactions.
