Isomorphism between finite sets
In summary, isomorphic means there exists a bijection between two sets that preserves their structure. Two finite sets with the same number of unique elements are isomorphic to each other, as every element in one set can be mapped to the other without any left over. This also means that the sets are both 1-1 and onto. However, the word "unique" is redundant when describing the number of elements in a set. Additionally, the concept of isomorphism does not apply to sets that contain repeated elements, as that goes against the definition of a set.
pivoxa15
2,255
In general if two finite sets contain exactly the same number of unique elements than the two sets are isomorphic to each other. Is this correct?
An isomorphism => both 1-1 and onto. If two sets both have an equal number of unique elements than they must be onto because every element in one set is mappped to the other with none left. It is 1-1 because each unique element in one set maps to another unique element (that hasen't already been mapped).
This is correct. And you're being redundant with the word "unique": the set {2, 2} has one element.
Your proof has the right idea, I think, but you need to work on its execution. Unfortunately I have to leave for work, but hopefully someone will explain in the meanwhile.
'They'? Sets are not onto, a map is onto (or not).
What mapping? You're talking as if there is only one map (whatever the 'it' refers to in your sentence) between any two sets.Firstly, what does it mean for a finite set to have n elements? It means that it is in bijection with the set {1,2,3..,n}. So the question is trivial by the definition of 'has n elements' and the transitivity of the relation 'are isomorphic'.
Interesting reply. I didn't know the definition of a finite set to have n elements is for there to exist a function that is a bijection with the set {1,2,3,..,n}.
You never learned to count?:rolleyes:
I guess I never learned to count formly, only intuitively.
But what happens if sometimes you want a set to contain {2,2} such as in sampling and 2 people both donate 2 apples. So double 2 is significant and {2} would be incorrect in this case.
By the way, I would not use the word "isomorphic" with sets- I would say "equivalent". Isomorphic, to me, implies algebraic structure.
Then you are not talking about "sets". I don't know that there is a standard mathematical term ("multi-set"?) for such a thing but C programming calls them "bags"!
then you're completely abusing the definition of a set. So stop doing so and obey the rules.
by tthe way, I would not use the word "isomorphic" with sets- I would say "equivalent". Isomorphic, to me, implies algebraic structure.
then'y you are sadly mistaken, again. Sets are isomorphic precisely when they contain the same number of elements. This is a trivial consequence of the definitions of set, isomorphism and 'same number of elements'.
matt, those are quotes from two different people. (So I'm not sure the word "again" applies here. Certainly, I have been "sadly mistaken" many times in the past but I think there's only one real howler on my part here!)
I will assert again that I had never seen the word "isomorphism" applied to "raw" sets without any other structure. I will concede that the general definition of isomorphism, an invertible function that preserves the algebraic structure, would still apply when there is NO algebraic structure to preserve!
They are not from two different people. They are from one person, and even from the same post, post 7. And not from you.
And you have seen the word isomorphism applied just to sets - the category SET. An isomorphism is precisely a bijection.
Funny because I clearly don't remember typing this "By the way, I would not use the word "isomorphic" with sets- I would say "equivalent". Isomorphic, to me, implies algebraic structure." It dosen't sound like me and definitely not in front of people like Matt and the mentors.
It appears in post 7 and nowhere before, so it can't be a quotation error (you know, when you quote a post, but get the [ quote ] and [/ quote] tags in the wrong place.
Hmm. But look at post 7 again. It says last edited by Halls of Ivy at... on the top. Why is Halls editing pixova's post? Very odd.
Odd, I was absolutely certain that I had made the remark about "isomorphism" applying only to sets with an algebraic structure.
Oh, you're talking about category theory! Never touch it! When I took my one course in it, the author of the textbook noted that category theory was also called "abstract nonsense"!
Ah, I know what happened now! They let us "mentors" edit other people's posts (doesn't that raise your hackles!). I hit the 'edit' button instead of 'quote' without realizing it. The last paragraph was mine and was supposed to be added to a quote.
Category theory is the theoretical underpinning of modern mathematics almost precisely because it is abstract nonsense. It is not an insult. It frequently gets to the real reason why things are true rather than relying unnecessarily on the ambient area in which you're reasoning.
Anyway, an isomrphism is an invertible morphism. In set that is a bijection. A monomorphism is a map with the left cancellation property, which in SET means injection. An epimorphism is a map with the right cancellation property, and that means surjection in SET. But not in RING. An epimorphism need not be surjective in RING. The canonical example is the inclusion of Z in Q. Any ring hom out of Q is completely determined by the image of Z in Q. Thus the inclusion is a non-surjective epimorphism.
Related to Isomorphism between finite sets
1. What is isomorphism between finite sets?
Isomorphism between finite sets is a concept in mathematics that describes the relationship between two sets that have the same number of elements and the same structure. In other words, it is a way to show that two sets are essentially the same, even if they are represented differently.
2. How is isomorphism between finite sets different from bijection?
Isomorphism between finite sets is a type of bijection that not only shows a one-to-one correspondence between the elements of two sets, but also preserves the structure and operations of the sets. This means that the elements of the two sets can be mapped to each other in a way that maintains their relationships with each other.
3. What are some examples of isomorphism between finite sets?
A classic example of isomorphism between finite sets is the relationship between a deck of playing cards and a set of numbers from 1 to 52. Both have 52 elements and can be arranged in different ways, but they have the same structure and operations (i.e. shuffling, dealing) that preserve their relationships. Another example is the relationship between a Rubik's cube and a permutation group of 54 elements.
4. How is isomorphism useful in mathematics?
Isomorphism between finite sets is useful in mathematics because it allows us to study and prove properties of one set by applying them to another set that is isomorphic to it. This can make complex concepts easier to understand and prove, and can also help us identify patterns and similarities between seemingly different sets.
5. Can isomorphism occur between infinite sets?
No, isomorphism is only defined for finite sets. However, there is a similar concept called "isomorphism of infinite sets" that is used to describe the relationship between infinite sets that have the same cardinality (i.e. the same number of elements). Isomorphism between infinite sets is more complex and is not as commonly used as isomorphism between finite sets.
