Kinematics- Child running down a hill
In summary, the conversation was about a child running down a hill and jumping upwards at an angle, with the question being what their initial speed was. The individual attempted to use trigonometry and the equation V^2-Vo^2=2ad to solve for the distance and velocity, but their answer of 10.1 m/s was found to be incorrect.
panozg
A child runs down a 13 hill and then suddenly jumps upward at a 17 angle above horizontal and lands 1.5 down the hill as measured along the hill. What was the child's initial speed?
Unknown. Been trying to use trig to solve distances and as a result velocity.
distance below starting point: y=1.5sin13=0.337 m
distance away (x): x=1.5cos13=1.46 m
as a result used 1.46 to figure out height above starting position with angle 17 degrees.
1.46tan17=0.446 m
V^2-Vo^2=2ad
0-Vo^2=2(-9.8)(.446)
Vo=2.9566 m/s
sin17=2.9566/V
V=10.1 m/s
THIS IS INCORRECT
I would first commend the student for their efforts in using trigonometry to solve the problem. However, it seems that there may be some errors in their calculations. To accurately solve this problem, we would need to consider the initial velocity of the child, the acceleration due to gravity, and the displacement of the child along the hill. Additionally, the angle at which the child jumps may also affect their final landing position.
To solve this problem, we can use the kinematic equations:
1. Displacement: x = x0 + v0t + 1/2at^2
2. Velocity: v = v0 + at
3. Final velocity: v^2 = v0^2 + 2ax
Using the given information, we can set up the equations as follows:
1. For the child's motion down the hill:
x = 0 + v0t + 1/2(9.8)t^2
2. For the child's motion up the hill:
x = 1.5 + v0t + 1/2(-9.8)t^2
Since the child lands 1.5m down the hill, we can set these two equations equal to each other and solve for t:
0 + v0t + 1/2(9.8)t^2 = 1.5 + v0t + 1/2(-9.8)t^2
1.5 = 2v0t
Now, we can use the third kinematic equation to solve for the initial velocity:
v^2 = v0^2 + 2ax
0 = v0^2 + 2(9.8)(1.5)
v0 = 4.39 m/s
Therefore, the child's initial speed down the hill was 4.39 m/s. It is important to note that this solution assumes that the child's motion is in one dimension and that air resistance is negligible.
FAQ: Kinematics- Child running down a hill
What is kinematics?
Kinematics is the branch of physics that studies the motion of objects without considering the forces that cause the motion.
How does kinematics apply to a child running down a hill?
Kinematics helps us understand the motion of the child as they run down the hill, including their speed, acceleration, and distance traveled.
What factors affect the child's motion while running down a hill?
The child's speed, acceleration, and the slope of the hill are the main factors that affect their motion. Other factors such as wind resistance and surface friction may also play a role.
What is the difference between speed and velocity in kinematics?
Speed is the measure of how fast an object is moving, while velocity includes both speed and direction of motion. In the case of a child running down a hill, their speed may change as they accelerate or decelerate, but their velocity will also take into account the direction they are traveling.
Can kinematics be used to predict the child's motion?
Yes, kinematics equations can be used to predict the child's future motion based on their current speed, acceleration, and direction. However, external factors such as obstacles or changes in the hill's slope may affect the predictions.
