Lagrange-Charpit equations for specific expression
In summary: P In summary, the Lagrange-Charpit equations can be written as pq-yp-xq = 0, with the function F(x,y,u,p,q) = pq-yp-xq. The characteristic equations are given by \frac{ dx}{ dt} = q-y, \frac{ dy}{ dt} = p-x, \frac{ du}{ dt} = qp, \frac{ dp}{ dt} = q, and \frac{ dq}{ dt} = p. By taking the second derivative of p with respect to t, we can see that \frac{ d
gtfitzpatrick
379
write down the Lagrange-Charpit eqs for
[tex] \frac{ \partial u}{ \partial x} \frac{ \partial u}{ \partial y} - y \frac{ \partial u}{ \partial x} - x \frac{ \partial u}{ \partial y}= 0 [/tex]
and use them to show [tex] \frac{ d^2 p}{ d p^2} = P [/tex]
assuming that u = x^2 when y=0 determine the characteristic curves (x(t),y(t))
so out eq gives pq-yp-xq = 0 so F(x,y,u,p,q) = pq-yp-xq
so
F_x = -q
F_y = -p
F_p = q-y
F_q = p-x
F_u = 0
so the char. eqs are
[tex] \frac{ dx}{ dt} [/tex] = q-y
[tex] \frac{ dy}{ dt} [/tex] = p-x
[tex] \frac{ dx}{ dt} [/tex] = qp
[tex] \frac{ dx}{ dt} [/tex] = p
so [tex] \frac{ dx}{ dt} [/tex] = q-p but then [tex]{ d^2 p}{ d p^2} = 0 [/tex]? what am i doing wrong, any ideas anyone?
I think there is a problem with notation here.
Mat
so
F_x = -q
F_y = -p
F_p = q-y
F_q = p-x
F_u = 0
[tex] \frac{ du}{ dt} [/tex] = qp
[tex] \frac{ dp}{ dt} [/tex] = q
[tex] \frac{ dq}{ dt} [/tex] = p
sorry this should read-
so [tex] \frac{ dp}{ dt} [/tex] = q but then [tex]\frac{ d^2 p}{ d t^2} = 0 [/tex]
[tex] \frac{ dp}{ dt} [/tex] = qp
[tex] \frac{ dq}{ dt} [/tex] = q
[tex] \frac{ du}{ dt} [/tex] = p
I think you mean
[tex] \frac{ dq}{ dt} = p[/tex]
[tex] \frac{ dp}{ dt} = q[/tex]
Then
[tex]\frac{ d^2 p}{ d t^2} = \frac{ dq}{ dt} [/tex]
which is not zero.
Note, I believe that you also have a mistake in [tex]du/dt[/tex], so you might want to double check that.
fzero said:
I think you mean
Then
which is not zero.
thanks i had made a mistake in du/dt. I am not sure now
FAQ: Lagrange-Charpit equations for specific expression
What is the Lagrange-Charpit equation?
The Lagrange-Charpit equation is a partial differential equation used in mathematics to solve problems involving two independent variables. It is commonly used in fluid dynamics and other areas of physics.
How is the Lagrange-Charpit equation derived?
The Lagrange-Charpit equation is derived from the method of characteristics, which is a technique used to solve first-order partial differential equations. It involves finding a set of curves, called characteristics, that satisfy the equation.
What are the applications of the Lagrange-Charpit equation?
The Lagrange-Charpit equation has many applications in mathematics and physics, particularly in problems involving fluid flow, heat transfer, and electromagnetic fields. It is also used in economics and finance to model the behavior of markets.
How do I solve a problem using the Lagrange-Charpit equation?
To solve a problem using the Lagrange-Charpit equation, you first need to identify the independent and dependent variables in the equation. Then, use the method of characteristics to find the characteristics curves and their corresponding equations. Finally, use the initial conditions to determine the values of the unknown functions.
Are there any limitations to using the Lagrange-Charpit equation?
The Lagrange-Charpit equation has some limitations, such as only being applicable to certain types of problems and not being able to handle certain boundary conditions. It also requires a high level of mathematical knowledge and skill to use effectively.
