Lesser the radius the lesser the volume. Why?
In summary, when comparing two planets with different radii and masses, the planet with a smaller radius will have a smaller volume and mass. This is because the radius and volume of a sphere are related by a geometrical formula and do not depend on physics. Doubling all dimensions results in an 8x increase in volume and mass, while halving all dimensions results in a 1/8 decrease in volume and mass. This can be seen visually by looking at cubes with different numbers of cubes per side.
avito009
184
If we take two planets One Earth and another one with half the radius of Earth. The planet with half the radius has lesser than half of the volume of the Earth. Also given that mass is half. Why?
Is it because lower radius and lesser mass means lesser gravity and lesser gravity can pull lesser matter towards the core?
Radius and volume of a sphere are related by [itex] V=\frac{4}{3} \pi R^3 [/itex]. Its completely geometrical and has nothing to do with physics!
http://imgur.com/UKHLp4n
Doubling all dimensions means 8x the volume and mass. Halving all the dimensions means 1/8 the volume and mass.
Looking at these cubes in the image link should explain it very intuitively. If there are 2 cubes per side there are a total of 8 cubes. If there are 4 cubes per side, there are a total of 64 cubes.
Area is x*y so it's squared. Volume is x*y*z so it's cubed. Therefore a 2x increase in dimensions means 2*2=4 increase in area and 2*2*2=8 increase in volume (and therefore mass).
FAQ: Lesser the radius the lesser the volume. Why?
Why does the volume decrease as the radius decreases?
As the radius decreases, the volume also decreases because volume is directly proportional to the radius cubed. This means that even a small change in the radius can result in a significant change in the volume. When the radius decreases, the amount of space inside the object also decreases, resulting in a decrease in volume.
Is there a mathematical equation that explains the relationship between radius and volume?
Yes, the mathematical equation that represents the relationship between radius and volume is V = (4/3)πr³, where V is the volume and r is the radius. This equation shows that the volume is directly proportional to the radius cubed.
Can you provide an example of how this concept applies in real life?
One example is a balloon. As you blow air into a balloon, the radius increases and so does the volume. When you let the air out, the radius decreases and so does the volume. This is because the volume of the balloon is directly related to its radius.
Does this concept apply to all shapes and objects?
Yes, this concept applies to all shapes and objects, as long as they have a defined radius. For example, it applies to spheres, cylinders, cones, and even irregularly shaped objects as long as their radius can be measured.
Are there any exceptions to this concept?
There are some exceptions to this concept, such as objects with varying densities. In these cases, even if the radius decreases, the volume may not necessarily decrease because the density of the object may change. However, for most objects with a constant density, the volume will decrease as the radius decreases.
