Lie algebra, ideal and isomorphism
In summary, the conversation revolves around the correctness of the claim that (A+I)/I \simeq A/I, where A and I are subalgebras of a Lie algebra, and I is an ideal. The conversation suggests reviewing the definitions of ideal and module in Lie and ring theory, as well as the precise statement of Noether's formula (A+B)/B \simeq A/(A \cap B). The conversation also includes a proof of the claim and discusses the potential errors in the proof. The conversation concludes with a suggestion to review sources and to ask for further clarification if needed.
jostpuur
2,116
Suppose [itex]A\subset\mathfrak{g}[/itex] and [itex]I\subset\mathfrak{g}[/itex] are subalgebras of some Lie algebra, and I is an ideal. Is there something wrong with an isomorphism [itex](A+I)/I \simeq A/I[/itex], [itex]a+i+I=a+I\mapsto a+I[/itex], for [itex]a\in A[/itex] and [itex]i\in I[/itex]? I cannot see what could be wrong, but all texts always give a theorem [itex](I+J)/J\simeq I/(I\cap J)[/itex] instead.
Review your sources?
"All texts always give a theorem"?
It is never a bad idea to cite your sources, and usually a good idea. In fact, if you had checked your sources before posting, you might have answered your own question.
I suggest that you review:
1. the definition of ideal in Lie theory versus ring theory,
2. the definiton of a module in ring theory,
3. the precise statement of Noether's formula [itex](A+B)/B \simeq A/(A \cap B)[/itex].
If this doesn't help, ask again.
It could be my post was more confusing than I intended, because I don't know this "Noether's formula" if it exists also elsewhere than in theory of Lie groups. I have two sources: https://www.amazon.com/dp/0817642595/?tag=pfamazon01-20 and lecture notes of course in University of Helsinki. They both present this theorem, and Knapp puts it like this:
If [itex]\mathfrak{g}[/itex] is a Lie algebra and if [itex]\mathfrak{a}[/itex] and [itex]\mathfrak{b}[/itex] are ideals in [itex]\mathfrak{g}[/itex] such that [itex]\mathfrak{a}+\mathfrak{b}=\mathfrak{g}[/itex], then
[tex]
\mathfrak{g}/\mathfrak{a} = (\mathfrak{a}+\mathfrak{b})/\mathfrak{a} \simeq \mathfrak{b}/(\mathfrak{a}\cap\mathfrak{b}).
[/tex]
In fact, the map from left to right is [itex]A+B+\mathfrak{a}\mapsto B+(\mathfrak{a}\cap\mathfrak{b})[/itex]. The map is known from linear algebra to be a vector space homomorphism, and we easily check that it respects brackets.
I thought I understood this, until I noticed that to me it seems that also the other claim, I presented in OP, is correct. And it seems strange if they both were correct, so now I think that there is something wrong with the claim, but I cannot see what.
(Now I used the same notation as Knapp does, which is different from the notation in the OP. Sorry for the confusion)
Or is there anything wrong with the claim? Could the theorem continued to be
[tex]
\cdots\simeq\mathfrak{b}/(\mathfrak{a}\cap\mathfrak{b}) \simeq \mathfrak{b}/\mathfrak{a} ?
[/tex]
If it can, then why is it written in the intersection form, when this one is simpler?
I'm not trying to be difficult...
... but you'll learn more if you figure it out yourself.
I really think that reviewing the definitions and so on would be a very good idea! However, ask again if this really doesn't help.
Incidently, Prof. Knapp was my analysis teacher (when I was an undergraduate at Cornell; Knapp later moved to SUNY Stony Brook).
Chris's idea of reviewing things carefully is a good one, but I think it doesn't emphasise this point enough, and might make you try to look too hard for something that is obvious
What is A/I if A is just some subalgebra of g and I is some ideal of g?
Basic stuff:
For an element of a algebra, X, and a subalgebra [itex]\mathfrak{a}[/itex], the coset is defined [itex]X+\mathfrak{a}=\{X+A\;|\;A\in\mathfrak{a}\}[/itex]. An important property is
[tex]
X+\mathfrak{a}=X'+\mathfrak{a} \quad\Leftrightarrow\quad X-X'\in\mathfrak{a}
[/tex]
If [itex]\mathfrak{g}[/itex] is a Lie algebra, and [itex]\mathfrak{a}[/itex] is its subalgebra, a quotient set is defined [itex]\mathfrak{g}/\mathfrak{a}=\{X+\mathfrak{a}\;|\;X\in\mathfrak{g}\}[/itex]. For this to be a Lie algebra, [itex]\mathfrak{a}[/itex] should be an ideal. Otherwise the bracket operation is not necessarily well defined.
Comments on possible mistakes here are welcome.
Doubts:
The claim
[tex]
\mathfrak{b}/(\mathfrak{a}\cap\mathfrak{b})\simeq \mathfrak{b}/\mathfrak{a}
[/tex]
doesn't make fully sense, because the right side is a Lie algebra if [itex]\mathfrak{a}[/itex] is an ideal, but for the left side both [itex]\mathfrak{a}[/itex] and [itex]\mathfrak{b}[/itex] should be ideals. Am I on the right track? But if we assume them both to be ideals, I still cannot see what's wrong with the proof.
I don't see any problems arising from a possible case where we have strictly [itex]\mathfrak{b}\subset\mathfrak{a}[/itex]. [itex]\mathfrak{b}/\mathfrak{a}[/itex] merely becomes a trivial group, but it's still well defined.
Proof:
Let [itex]\mathfrak{a},\mathfrak{b}\subset\mathfrak{g}[/itex] be ideals of some Lie algebra. Then
[tex]
f:\mathfrak{b}/(\mathfrak{a}\cap\mathfrak{b})\to\mathfrak{b}/\mathfrak{a},\quad\quad f(B+\mathfrak{a}\cap\mathfrak{b})=B+\mathfrak{a}
[/tex]
is an isomorphism.
The map is well defined because
[tex]
B+\mathfrak{a}\cap\mathfrak{b} = B' + \mathfrak{a}\cap\mathfrak{b} \quad\implies\quad B-B'\in\mathfrak{a}\cap\mathfrak{b} \quad\implies\quad B-B'\in\mathfrak{a} \quad\implies\quad B+\mathfrak{a} = B'+\mathfrak{a}
[/tex]
Similarly it is also injective because
[tex]
B-B'\notin \mathfrak{a}\cap\mathfrak{b} \quad\big(\textrm{and}\; B-B'\in\mathfrak{b}\big) \quad\implies\quad B-B'\notin\mathfrak{a}
[/tex]
The map is surjective because for arbitrary [itex]B+\mathfrak{a}[/itex] we can choose [itex]B+\mathfrak{a}\cap\mathfrak{b}[/itex].
The map is Lie algebra homomorphism because
[tex]
f([B+\mathfrak{a}\cap\mathfrak{b},\;B'+\mathfrak{a}\cap\mathfrak{b}]) = f([B,B']+\mathfrak{a}\cap\mathfrak{b}) = [B,B']+\mathfrak{a} = [B+\mathfrak{a},\;B'+\mathfrak{a}] = [f(B+\mathfrak{a}\cap\mathfrak{b}),\; f(B'+\mathfrak{a}\cap\mathfrak{b}])
[/tex]
I still don't know if I'm supposed to figure out that my claim is wrong or that it is right.
Very cool.
Nope, you're looking too hard. If I have A a subalgebra of g, and I an ideal of g, how are you defining the quotient space A/I? I know how to define the quotient space g/I, for example, because I is an ideal of g, but is I an ideal of A?
Ahaa... so it doesn't make sense to write A/I according to the standard definitions, because I is not necessarily an ideal of A. But if I still define it like this
[tex]
A/I=\{X+I\;|\;X\in A\}
[/tex]
It seems to be isomorphic to [itex]A/(A\cap I)[/itex].
But is A\cap I an ideal? I.e. does it make sense to write A/(A\cap I)? As a vector space, you're certainly correct, but that isn't necessarily a Lie algebra homomorphism.
In fact I think I proved this! I thought it was something that the book assumes, that reader must be able to figure out on his own.
So [itex]A\subset\mathfrak{g}[/itex] and [itex]I\subset\mathfrak{g}[/itex] are subalgebras of some Lie algebra, and I is an ideal. Now I want to prove that [itex]A\cap I[/itex] is an ideal in A (oh and yeah, not in [itex]\mathfrak{g}[/itex]...)
Let [itex]x\in A[/itex] and [itex]i\in A\cap I[/itex] be arbitrary.
[itex]x,i\in A[/itex], so because A is a subalgebra, we have [itex][x,i]\in A[/itex].
[itex]x\in A[/itex] and [itex]i\in I[/itex], so because I is an ideal, we have [itex][x,i]\in I[/itex].
Therefore [itex][x,i]\in A\cap I[/itex], and [itex][A, A\cap I]\subset A\cap I[/itex].
Back to square one, with benefit of more experience
Jostpuur, I recommend that you carefully reread my first reply above and see if it makes more sense now. Then review all the definitions again (and the statement of Noether's formula--- make sure you know all the hypotheses). I really think you'll learn more if you figure this out yourself since your question is based upon misconceptions which are apparently due to not thinking about the issues I raised.
(I hope everyone realizes that I am trying not to give jostpuur a fish, but to teach him how to fish, as the proverb goes.)
This is the only context where I have seen this formula. But I can guess from Chris' comments, that there is some other theorem, not related to lie algebras, where this same formula is also present. I don't have this theorem at any sources now, and it seems difficult to find it by google and keywords "noether's formula" (OMG, the 9th google hit is my own thread! , googled 2007-09-13)
I thought I already understood this. The equation
[tex]
[/tex]
was correct in the sense, that if you write down both sides with expression [itex]A/B:=\{a+B\;|\;a\in A\}[/itex], they are isomorphic, but it is bad notation because in the definition of a quotient group we assume [itex]B\subset A[/itex], and hence the left side is preferred.
Now if that's wrong, then please explain. I'm believing in this now.
jostpuur said:
The equation
[tex]
[/tex]
ahem. assume? No, it is part of the definition.
the left side of what?
Related to Lie algebra, ideal and isomorphism
1. What is a Lie algebra?
A Lie algebra is a mathematical structure that studies the properties of vector spaces and their associated operations, such as addition and multiplication. It is used to analyze continuous symmetries and transformations in mathematical objects, particularly in the field of group theory.
2. What is an ideal in a Lie algebra?
An ideal in a Lie algebra is a subset of the algebra that is closed under the operation of taking commutators with elements of the algebra. It is a generalization of the concept of an ideal in a ring, and plays a crucial role in the study of Lie algebras.
3. How are ideals related to isomorphisms in Lie algebras?
Ideals are closely related to isomorphisms in Lie algebras. If two Lie algebras have isomorphic ideals, then they are considered isomorphic themselves. This means that they have the same structure and properties, even if the elements and operations may look different.
4. What is an isomorphism in Lie algebras?
An isomorphism in Lie algebras is a mapping between two Lie algebras that preserves the algebraic structure. In simpler terms, it is a one-to-one correspondence between the elements of two Lie algebras that respects the operations and relationships between those elements.
5. How are Lie algebras, ideals, and isomorphisms used in real-world applications?
Lie algebras, ideals, and isomorphisms have numerous applications in physics, particularly in the study of symmetries and transformations. They are also used in other areas of mathematics, such as differential geometry and representation theory. In real-world applications, they can be used to model and analyze complex systems, such as in quantum mechanics and computer graphics.
