Light in medium, time gets affected?
In summary, when a ray of light passes through a medium with a refractive index, the speed of light is reduced due to the cancellation of electric fields. This does not affect the motion of time inside the medium. The concept of group velocity, which is different from the velocity of photons in a medium, can help understand this further. You can learn more about group velocity and its relation to the speed of light in a solid medium by reading the PF FAQ thread in the General Physics forum.
A Dhingra
211
hi ...
when a ray of light passes through a medium of some refractive index, then due to cancellation of electric fields the speed of light reduces inside the medium as compared to air. with this thought in mind, can we say that, as the speed of light has got reduced , there is something happening to the motion of time inside the medium. either time slows down or becomes faster.
Is that reduce in speed of light affects the time?
( i guess it does not, but i am not sure... so please provide proper reason behind the answer)
thanks
Science news on Phys.org
Please start by reading the PF FAQ thread in the General Physics forum.
You also need to learn the difference between group velocity, and the velocity of photons in such a medium.
Zz.
the explanation about "Do Photons Move Slower in a Solid Medium?" was amazing...
where can i get to read about group velocity and its relation to this...
for your question. The concept of time and its relationship with light is a complex and fascinating topic in science. While it is true that the speed of light is affected when passing through a medium, this does not necessarily mean that time is affected as well.
First, let's clarify that the speed of light is not actually reduced, but rather it appears to be reduced due to the medium's refractive index. This means that the light is still traveling at the same speed, but it is taking a longer path due to the medium's properties.
Now, let's consider the concept of time. Time is a fundamental aspect of our universe and is often described as the fourth dimension. It is a constant and does not change based on the medium through which light is passing. This means that time is not affected by the speed of light, even if it appears to be slower when traveling through a medium.
To understand this better, let's look at Einstein's theory of relativity. According to this theory, time and space are interconnected and can be affected by gravity and acceleration. However, the speed of light is still considered a constant in all reference frames, meaning that it does not change regardless of the medium or the observer's perspective.
In summary, the speed of light may appear to be reduced when passing through a medium, but this does not affect the fundamental concept of time. Time remains constant and is not affected by the speed of light. I hope this helps clarify your question.
FAQ: Light in medium, time gets affected?
How does the speed of light change when traveling through different mediums?
The speed of light changes when traveling through different mediums because of the interaction between light and the particles of the medium. In a vacuum, light travels at a constant speed of 299,792,458 meters per second. However, when it enters a medium such as water or glass, it slows down due to the interaction with the particles in the medium.
Why does the speed of light change when traveling through mediums?
The speed of light changes because of the refractive index of the medium. The refractive index is a measure of how much a medium can bend or slow down light. The higher the refractive index, the slower the speed of light in that medium.
How does time dilation occur when light travels through a medium?
When light travels through a medium, it experiences time dilation because the speed of light is slower in the medium compared to a vacuum. This means that the time it takes for light to travel a certain distance in the medium is longer compared to traveling the same distance in a vacuum. This effect is also known as the time delay of light in a medium.
Can the speed of light in a medium ever be faster than the speed of light in a vacuum?
No, the speed of light in a medium can never be faster than the speed of light in a vacuum. The speed of light in a vacuum is the maximum speed at which anything in the universe can travel. In fact, the speed of light in a medium is always slower than the speed of light in a vacuum.
How does the interaction between light and matter affect the speed of light in a medium?
The interaction between light and matter, such as absorption and re-emission, can also affect the speed of light in a medium. When light is absorbed by the particles in a medium, it gets converted into other forms of energy, causing a delay in its speed. When the light is re-emitted, it may travel at a different speed depending on the properties of the particles in the medium.
