Linear expantion and elastic modulus- brass vs. glass
In summary, linear expansion refers to the tendency of a material to increase or decrease in length when heated or cooled. Brass and glass have different coefficients of linear expansion, with brass having a higher coefficient and therefore expanding and contracting more than glass. The elastic modulus, which measures a material's stiffness, is also different between brass and glass, with brass having a higher modulus. This affects how easily a material can change in length when exposed to temperature changes. The comparison of brass and glass in terms of linear expansion and elastic modulus is important for understanding how different materials behave under temperature changes, which is crucial in fields such as engineering and construction.
mmoadi
157
Onto a thick brass rod we attach equally long glass thread. At what temperature change will the glass thread break if the temperature coefficient of linear expansion for brass is
α1= 20 x 10 ^-6 K^-1, and for glass is α2= 7 x 10^-6 K^-1? Young’s (elastic) modulus for glass is E1= 7 x 10^10 N/m², and shear modulus for glass is σ1= 7 x 10^7 N/m².
Linear thermal expansion: α(L)= ΔL/ L(0)ΔT
Young’s (elastic) modulus: E= FL(0)/ AΔL
Thank you mgb_phys for hint- it helped a lot:
Qute: "You don't need a relation between them as such.
You use the modulus for glass to work out at what strain the glass would break.
Then you use the relative expansion of brass and glass to work out at what temperature the glass would have been stretched that amount.
hint. remember the glass is also expanding as the brass does" (mgb_phys)
So I calculated strain:
Strain: ε= ΔL/ L
Stress: σ= F/A
E= FL(0)/ AΔL → E= stress/strain= σ/ ε → ε= σ/ E
ε = 7 x 10^7 N/m²/ 7 x 10^10 N/m²
ε= 0.001
But now, I don't know how to combine brass and glass to find the final answer.
I tried this, but I doubt is correct:
α(L-glass)= [ΔL/ L(0)]/ ΔT= ε/ ΔT → ΔT= ε/ α(L-glass)
ΔT= 0.001/ 7 x 10^-6 K^-1
ΔT=0.14 x 10^3 K= 140 K
Is this correct (big doubt?!, too low temperature)?
Any hints?
Thank you for helping!
Your approach is on the right track, but there are a few things to consider:
1. The strain you calculated is for the shear modulus, but you need to use the Young's modulus for this problem. So you should use E=FL(0)/AΔL instead.
2. The strain you calculated is for the glass thread, but you also need to consider the expansion of the brass rod. So your equation should include both materials, like this: ΔT= ε/(α1L-brass + α2L-glass)
3. Make sure you convert the units properly. The strain should be in meters per meter, so you may need to convert the dimensions to meters before calculating the strain.
4. Your final answer is in Kelvin, which is the correct unit for temperature change. But it might be helpful to also convert this to Celsius, which is a more intuitive unit for temperature change.
With these adjustments, you should be able to calculate the correct temperature change at which the glass thread will break. Good luck!
I would suggest looking at the problem from a different angle. Instead of trying to combine the properties of brass and glass, it may be more useful to consider the properties of glass alone.
Using the given values, we can calculate the maximum strain that the glass thread can withstand before breaking:
σ = Eε → ε = σ/E = (7 x 10^7 N/m²)/(7 x 10^10 N/m²) = 0.001
This means that the glass thread can withstand a maximum strain of 0.001 before breaking. Now, we can use the coefficient of linear expansion for glass to determine the temperature change that would cause this strain:
α(L-glass) = ΔL/ L(0)ΔT → ΔT = ΔL/(L(0)α(L-glass)) = (0.001)/(7 x 10^-6 K^-1) = 143 K
Therefore, the glass thread will break when the temperature changes by 143 K. Since the coefficient of linear expansion for brass is larger than that for glass, the brass rod will expand more than the glass thread and cause it to break.
Related to Linear expantion and elastic modulus- brass vs. glass
1. What is linear expansion?
Linear expansion is the tendency of a material to increase its length when heated and decrease its length when cooled. This is due to the increase or decrease in the spacing of atoms or molecules within the material.
2. How does linear expansion affect brass and glass differently?
Brass and glass have different coefficients of linear expansion, which means they expand and contract at different rates when exposed to the same change in temperature. Brass has a higher coefficient of expansion, meaning it expands more than glass when heated and contracts more than glass when cooled.
3. What is the elastic modulus of brass and glass?
The elastic modulus, also known as Young's modulus, is a measure of a material's stiffness or resistance to deformation. Brass has a higher elastic modulus than glass, meaning it is more difficult to stretch or compress.
4. How is the elastic modulus related to linear expansion?
The elastic modulus is related to linear expansion because it affects how easily a material can change in length when subjected to a change in temperature. Materials with higher elastic moduli, like brass, will resist changes in length more than materials with lower elastic moduli, like glass.
5. Why is the comparison of brass and glass important in terms of linear expansion and elastic modulus?
The comparison of brass and glass in terms of linear expansion and elastic modulus is important because it helps us understand how different materials behave when exposed to changes in temperature. This knowledge is crucial in various fields such as engineering and construction, where the effects of temperature changes on materials must be taken into consideration.
