Litz conductor surrounded by drain wires = huge capacitance?
In summary, the drain wires are there to provide capacitance to counteract inductance. They are not necessary for the cable to work, but they may increase the cable's power factor.
chopficaro
46
this type of cable is used to transfer power underground:
http://www.mahanson.com/images/Hendrix%20Cable.jpg
see the drain wires? i would think that those would be a huge problem because they are grounded and are right next to the conductor, i suppose any shielding would have this problem. the capacitance and thus the impedance of the wire must be HUGE.
Would this be any different than a conductor in a conduit run?
Have you looked at the cables specs?
Here's their catalog: http://www.hendrix-wc.com/hendrix/pdf/hendrix_catalog.pdf"
Most of the cables listed have inductive reactance specifications.
Huge shunt capacitance means low impedance, afaik.
But only a matter of pF per metre. And not a lot worse than the capacitance to the surrounding Earth if the cable is buried.
is that because the impedance of a capacitor is NEGATIVE -j/wc ?
thats a little confusing because it begs the question
which is greater
j
or
-j
or maybe it is the case that the inductance of a litz wire is always greater than any capacitance, so that any capacitance will counteract the inductance for a smaller impedance?
The inductance per metre would be very very low (a series element) and the shunt reactance would be very high for such a small capacitance.
Why should the litz wire have a large inductance? It would be the inductance of a lot of parallel inductances, surely?
What is the intended function of the 'drain' wires apart from providing a reliable and defined path to ground if the cable gets squashed?
i know these effects are small but i have to calculate them. maybe the purpose of the drain wired is to provide capacitance to counteract inductance
But as I said, there is plenty of capacitance when the cable is underground - with or without the drain wires. The capacitative effect is more than the inductive effect - underground cables have a worse power factor than overheads.
Use the transmission line equations and you will see what I mean.
FAQ: Litz conductor surrounded by drain wires = huge capacitance?
What is a Litz conductor?
A Litz conductor is a type of wire that is made up of multiple strands of smaller wires, twisted or braided together. This design reduces the skin effect, which is the tendency of high frequency currents to flow on the surface of a conductor rather than through its entire cross-section.
What are drain wires?
Drain wires are typically uninsulated wires that are placed around a Litz conductor. They are used to provide a path for the current to flow through, reducing the inductance and thus increasing the capacitance of the Litz conductor.
What is capacitance?
Capacitance is the ability of a conductor or system to store an electrical charge. It is measured in farads (F) and is influenced by factors such as the distance between conductors, the type of material used, and the geometry of the conductors.
How does a Litz conductor surrounded by drain wires create huge capacitance?
The design of a Litz conductor surrounded by drain wires reduces the inductance of the conductor, which increases the capacitance. The multiple strands of smaller wires reduce the skin effect, allowing more current to flow through the entire cross-section of the conductor. The drain wires provide a path for the current to flow through, further reducing the inductance and increasing the capacitance.
What are the applications of Litz conductors with drain wires?
Litz conductors with drain wires are commonly used in high frequency applications, such as inductors, transformers, and antennas. They are also used in power electronics, electric motors, and generators to reduce losses and improve efficiency. Additionally, they are used in medical devices, telecommunications equipment, and aerospace technology.
