Locally flat coordinates on the Poincaré half plane
In summary, the problem is to find the locally flat coordinates on the Poincaré half plane, using the Poincaré Metric. The author, A. Zee, explains that the metric can be transformed by choosing a new set of coordinates, which gives a lot of freedom to manipulate the metric into the desired form. The author then expands the metric around a point P and simplifies it, using the example of a sphere. The author also introduces the concept of changing coordinates and diagonalizing the metric. The exact method to find the locally flat coordinates is not clearly defined, and the author asks for further explanation or a clear method for finding them.
Whitehole
132
Find the locally flat coordinates on the Poincaré half plane.
Problem I.6.4 by A. Zee
[/B]
Poincaré Metric: ##ds^2 = \frac{dx^2 + dy^2}{y^2}##
First, I'm having problems with the explanation in Zee's book. He said that we can always choose our neighborhood to be locally flat for any space of any dimension D.
"Look at how the metric transforms when you go to a new set of coordinates:
##g'_{λσ}(x') = g_{μν}(x) \frac{∂x^μ}{∂x'^λ} \frac{∂x^ν}{∂x'^σ} ##
Within reason, you could choose any x you want, and for each choice, you get a new form for the metric. You have a lot of freedom to massage the metric into the form you want. The proof simply amounts to counting how much freedom you have on hand. So, look at our space around a point P. First, for writing convenience, shift our coordinates so that the point P is labeled by x = 0. Expand the given metric around P out to second order:
##g_{μν}(x) = g_{μν}(0) + A_{μν,λ}x^λ + B_{μν,λσ}x^λx^σ + ... ##
As always, if you get confused, you should simply refer to the sphere. Thus, let the coordinates of the point P be ##(θ_∗, ϕ_∗)##, so that ##x^1 = (θ − θ_∗)## , ##x^2 = (ϕ − ϕ_∗)##. (Of course, in this simple case, nothing depends on ##ϕ_∗##.) What we just wrote down is then simply, for example, ##g_{ϕϕ} = \sin^2θ = sin^2θ_∗ + 2sinθ_∗cosθ_∗x^1 + . . . ##, so that ##A_{ϕϕ},1 = 2sinθ_∗cosθ_∗## and ##A_{ϕϕ},2 = 0##. Nothing profound at all.
Change coordinates according to ##x^μ = K^μ_ν x'^ν + L^μ_{νλ} x'^νx'^λ + M^μ_{νλσ}x'^νx'^λx'^σ + . . .## . Again, nothing profound: K , L, M, . . . are just a bunch of coefficients to be determined. At the point P, the new metric is given by
##g'_{λσ}(0) = g_{μν}(0) K^μ_λK^ν_σ ##
Regard this as a matrix equation ##g = K^TgK##, where T denotes transpose. Since ##g_{μν}(0)## is symmetric and real, there always exists a matrix K that will diagonalize it. After ##g_{μν}(0)## becomes diagonal (with positive diagonal elements—we will take that as a definition of space), we could scale each coordinate, one by one, by an appropriate factor, so that the diagonal elements become 1. We end up with the Euclidean metric ##g_{μν}(0) = δ_{μν}##."
Following the first part of his explanation,
##ds^2 = \frac{dx^2 + dy^2}{y^2}## → ##g_{xx} = g_{yy} = \frac{1}{y^2}##
The metric is already diagonal so K is just the identity matrix, but how do I find L (for the second order term)? Generally, what is the exact way to find the locally flat coordinates. The explanation is kinda fuzzy. I can't point the exact method to find those.
If anyone can explain or provide me a clear method to find those, I would be very grateful.Thanks in advance.
Related to Locally flat coordinates on the Poincaré half plane
1. What is the Poincaré half plane?
The Poincaré half plane is a concept in mathematics, specifically in the field of hyperbolic geometry. It is a model of the hyperbolic plane, which is a non-Euclidean space with constant negative curvature. The Poincaré half plane is defined as the upper half plane in the complex plane, where the imaginary part is positive.
2. What are locally flat coordinates?
Locally flat coordinates, also known as intrinsic coordinates, are a set of coordinates that can be used to describe points on a curved surface. They are defined in such a way that the curvature of the surface is not apparent in the coordinates. In other words, in locally flat coordinates, the surface appears to be flat locally, even though it may have a non-zero curvature globally.
3. How are locally flat coordinates used on the Poincaré half plane?
On the Poincaré half plane, locally flat coordinates are used to describe points on the hyperbolic plane. This allows for easier calculations and geometric constructions, as the curved nature of the hyperbolic plane can be ignored locally. Locally flat coordinates also allow for the application of Euclidean geometry concepts on the hyperbolic plane.
4. What is the significance of locally flat coordinates on the Poincaré half plane?
The use of locally flat coordinates on the Poincaré half plane is significant because it allows for the study and understanding of hyperbolic geometry, which has numerous applications in fields such as physics, computer science, and even art. Locally flat coordinates also make it easier to visualize and work with the hyperbolic plane, which is a non-intuitive space.
5. Are there any limitations to using locally flat coordinates on the Poincaré half plane?
While locally flat coordinates are useful on the Poincaré half plane, they are not without limitations. They only apply to a small region of the hyperbolic plane and cannot be extended to cover the entire space. Additionally, they may not accurately represent distances and angles in the hyperbolic plane, as they are based on the Euclidean concept of parallel lines, which does not hold true in hyperbolic geometry.
