Looking to build a backyard windmill
In summary: I think unless you have a high tower, the ground turbulence would take away any advantage of complicated blades.Small wind turbines typically have blades that are about 6' across.A search for "marine wind generators" will turn up many resources on how to build and maintain small wind turbines. There are many small wind turbine kits available, or you can buy a complete wind generator.
BobJ
Hey all. I'd like to build a small windmill in my backyard. Small is I'm going to guess maybe 5 foot blades or so. I do CAD work so I can design most of the parts I need EXCEPT the blades. I have no idea where to start. I understand the basic shape, but I'm unclear where to start to get one going in the size range I need. Does anyone know of any good resources to get me going? Book, website or something? I don't have a CFD program, but would like to take a stab at the design so I can make it myself. Any advice is appreciated. Thanks!
note, I want this to be functional, i.e. generate power. Not for decoration. Thanks!
Google "marine wind generators". Some of the brands are Airx, and Kiss. You can buy spare blades for them. You can even buy a complete wind generator.
Thanks, I'm hoping to get some dimensions and design it from scratch if possible. I will check that search out.. thank you.
They break down frequently. You may be able to get a broken one free and use it as a template.
Owners of such windmills must learn to be windmill repair technicians pretty quickly.
thanks for the leads. I see some blades sets for not all that much. That's a good idea. I'll keep an eye out. Thanks!
many hobbyists cut blades from pvc pipe. A quick search turns up plenty of youtubes and instructables.
Blade design can get very complicated. A very simple but inefficient design is the savonius configuration which uses the PVC piping described earlier. Here is a student paper on the subject which should give you a head start.
http://www.engr.mun.ca/~blaines/Docs/Final%20Report-April-09.pdf
I have seen a very good, well designed and completely home made windmill it was constructed using an alternator from a car, a homemade center hub cut from diamond plate aluminum and an old ceiling fan. He just used the ceiling fan blade (brackets) and scaled up the length of the blades, he used plastic or Plexiglas he purchased from home depot to make the blades and they had to be 6' across. He had made it so it would pivot 180 degrees and used it to supplement a solar charging station he had build with a few car batteries an inverter and voltage regulator. He was able to power one Green outlet per room in his home.
Note he only used these outlets for lights (lamps) and a couple tvs but it worked
Likes OmCheeto
of complicated blades. I have seen some Savonius Turbines made with 55 gallon drums, that would help this.
About using an automotive alternator... I tried to make a water turbine with one, and found I was getting a disappointing amount of power from it... I was feeding it enough water to get about 300W, but was coming up short at about 100W... My turbine was not an efficient one, but it caused me to look into it deeper.
The alternator needs about 7A to generate the field, this 7A is taken away from your final power output, and that's about 100W @ 12V
Unless you're going to be operating it near it's rated power output (120A/1400W in my case) they really lose efficiency at lower outputs since the 7A field must be maintained.
If you can find a permanent magnet brushless generator you will probably realize better efficiency at low power outputs
I'm not sure how this guy had his rigged, but it had been modified it had a steady output at 12 volts when turning, BUT he also had several solar panels wired up to this inverter In fact the alternator was wired up to something different and run straight to the battery bank if memory serves me correctly.
He probably had a controller that varied the field current that would cut out above a set voltage.. an alternator with a built in regulator would do that automatically.
If you took the alternator rotor apart and replaced the field coil in it with a large permanent magnet you may improve the efficiency at low speed at the cost of having to use a different regulator setup and some loss of peak current capability... I haven't tried it, I wasn't involved enough on the project, but I would give it a shot.
If someone could figure out the methods he used for this (to get the steady 12 v from the recycled alternator) then the applications of this could be used to make working generators out several power sources, water wheels, windmills, old lawn mower engines, even old bikes (motorized or peddle powered) All out of old recycled material. I'd have to think that you'd need to put a capacitor in the line somewhere that only discharges at a steady 12 volts if the alternator spins at variable speeds. And it would probably need an alternate source of charging like solar and maybe a back up gas generator. But seems possible if you have the know how.
i've seen youtubes on converting alternators from wound field to permanent magnet
try a search
not for the faint of heart...
you can buy them already converted
http://www.windbluepower.com/Permanent_Magnet_Alternator_Rotor_Fits_Delco_10SI_p/pma-rot.htm
aha - somebody figured out how to use those newfangled washing machine motors
strip off the computer and get at the raw 3 phase machine...
blades ?
http://www.yourgreendream.com/diy_pvc_blades.php
Likes Rx7man
Related to Looking to build a backyard windmill
1. Can a backyard windmill generate enough electricity to power my entire house?
It depends on the size and efficiency of the windmill, as well as the average wind speeds in your area. In general, backyard windmills are better suited for supplementing your electricity usage rather than providing all of it.
2. How much does it cost to build a backyard windmill?
The cost can vary greatly depending on the type and size of the windmill, as well as the materials and labor involved. On average, a backyard windmill can cost anywhere from $3,000 to $10,000.
3. Do I need a permit to build a backyard windmill?
This also depends on your location. Some cities and towns may require a permit for building a windmill, while others may not. It's important to check with your local government before beginning construction.
4. How much maintenance does a backyard windmill require?
Backyard windmills require regular maintenance to ensure they are functioning properly. This can include lubricating moving parts, checking for wear and tear, and cleaning the blades. The amount and frequency of maintenance may vary depending on the specific windmill.
5. Can I connect my backyard windmill to the grid?
Yes, it is possible to connect your windmill to the grid to sell excess electricity back to your utility company. However, this process may require additional equipment and permits, so it's important to research and consult with professionals before attempting to connect to the grid.
44K
