fluidistic
- 264
Hi all,
I'm stupefied. In continuation to my last thread (https://www.physicsforums.com/showthread.php?t=277124), I wanted to see if any perfectly plastic collision would make the total mechanical energy of the system go down to a factor of [tex]\frac{1}{\sqrt 6}[/tex]. I got a strange result and I know it cannot be possible so there's at least one error. If you could find it out... I'd be grateful.Say you have initially 2 particles in motion. The first one has a mass [tex]m[/tex] and a speed of [tex]v_1[/tex]. Second one has a mass [tex]M[/tex] and a speed of [tex]v_2[/tex].
They collide and after the collision they remain attached. They form a new particle of mass [tex]M+m[/tex] and speed [tex]v_3[/tex]. (I assume speed instead of velocity to simplify but I might be wrong by doing this however).
The linear momentum is conserved. Putting away vectors, I have that [tex]P_i=P_f \Leftrightarrow mv_1+Mv_2=(M+m)v_3 \Leftrightarrow v_3=\frac{mv_1+Mv_2}{M+m}[/tex].
As the mechanical energy is not conserved I still want to find out the energy before and after the collision in order to compare them.
I have that [tex]E_i=\frac{mv_1^2+Mv_2^2}{2}[/tex] while [tex]E_f=\frac{(m+M)v_3^2}{2}=\frac{(mv_1+Mv_2)^2}{2(m+M)}[/tex].
I want to know how much times the initial energy is greater than the final. So [tex]E_i=\alpha E_f \Leftrightarrow \alpha= \frac{mv_1^2+Mv_2^2}{2} \cdot \frac{2(m+M)}{(mv_1+Mv_2)^2}[/tex] by expanding I finally get that [tex]\alpha=\frac{m^2v_1^2+Mmv_2^2+Mmv_1^2+M^2v_2^2}{m^2v_1^2+2mv_1Mv_2+M^2v_2^2}[/tex]. Note that the numerator and the denominator are almost equal, they only differ by the term "[tex]Mm(v_2^2+v_1^2)[/tex]" in the numerator and "[tex]2mv_1Mv_2[/tex]" at the denominator. But if you set [tex]v_1[/tex] and [tex]v_2[/tex] to be [tex]\frac {1m}{s} }[/tex], there are equal and as a consequence the mechanical energy is conserved...which is obviously wrong. Where did I go wrong?
Thank you very much.
