Lowest energy state with infinite and finite potential
In summary, the conversation discusses a problem with an electron confined to a region with differing potentials. The energy of the electron in the ground state is lower in the second region due to the wavefunction extending into the higher potential area. This difference is caused by the process of tunnelling.
omiros
30
Hello everyone and thanks for reading my post.
I have a problem with an electron, which actually is confined into a region 0 ≤ x≤ L with infinite potential around it, and its energy in the ground state is 0.38eV. Then on the x > L region the potential is 5eV and the energy of the lowest eigenstate is 0.32eV. What causes that difference?
Thanks for your time.
The different potential causes a difference.
In the second case, the wavefunction will extend a bit into the x>L-region. This is similar to a larger potential well, so the ground state has a lower energy.
Likes 1 person
I think the difference happen as a result of the TUNNELLING of the electron into the potential barrier.
FAQ: Lowest energy state with infinite and finite potential
What is the lowest energy state with infinite potential?
The lowest energy state with infinite potential refers to the state of a system where the potential energy is infinitely high. This means that the system is at its most stable state and has no further potential to release energy.
How is the lowest energy state with infinite potential different from the lowest energy state with finite potential?
The main difference between the two is that in a system with infinite potential, the energy is completely trapped and cannot be released, whereas in a system with finite potential, there is still some potential for energy to be released.
Can the lowest energy state of a system with infinite potential ever change?
No, the lowest energy state of a system with infinite potential is a constant state and cannot change. This is because the potential energy is infinitely high, leaving no room for further changes.
How can the lowest energy state with finite potential be determined?
The lowest energy state with finite potential can be determined by solving the Schrödinger equation for the given system. This equation takes into account the potential energy of the system and predicts the lowest energy state.
What happens if a system is not in the lowest energy state with finite potential?
If a system is not in its lowest energy state with finite potential, it will tend to move towards that state in order to achieve stability. This can happen through energy transfers or other processes that release energy from the system.
