Manipulating Exponents, Simple
  • Thread starter mohabitar
  • Tags
    Exponents
In summary, an exponent is a notation used in math to show the number of times a base number is multiplied by itself. To simplify expressions with exponents, you can use exponent rules and the order of operations. A positive exponent means the base number is multiplied by itself, while a negative exponent means the base number is divided by itself. Any number raised to the power of zero is equal to 1. And finally, a negative base with an even exponent will result in a positive answer.
mohabitar
140
Answering the above question is not really hard, but the question is how to change 32^24 to 2^120? Whats the method for that? Is there a formula I can use?
32=2^5. (a^b)^c=a^(b*c).
Thanks!
FAQ: Manipulating Exponents, Simple
What is an exponent?
An exponent is a mathematical notation that represents the number of times a base number is multiplied by itself. It is usually written as a superscript to the right of the base number.
How do you simplify expressions with exponents?
To simplify an expression with exponents, you can use the exponent rules. These rules include multiplying exponents with the same base by adding their powers, dividing exponents with the same base by subtracting their powers, and raising a power to another power by multiplying the powers. You can also use the order of operations to simplify expressions with multiple operations.
What is the difference between a positive and negative exponent?
A positive exponent indicates that the base number should be multiplied by itself the number of times specified by the exponent. A negative exponent, on the other hand, indicates that the base number should be divided by itself the number of times specified by the exponent. For example, 23 = 2 x 2 x 2 = 8, while 2-3 = 1 / (2 x 2 x 2) = 1/8.
How do you handle zero as an exponent?
Any number raised to the power of zero is equal to 1. This means that any expression with a base number raised to the power of zero can be simplified to 1. For example, 50 = 1 and (2x + 3)0 = 1.
Can you have a negative base with an even exponent?
Yes, you can. A negative base with an even exponent will result in a positive answer. This is because when multiplying a negative number by itself an even number of times, the negative signs will cancel out and the resulting number will be positive. For example, (-3)4 = (-3) x (-3) x (-3) x (-3) = 81.
