- #71
rodsika
- 279
- 2
JesseM said:No, the point is that some observables like position and momentum don't commute, so you have to decide whether the position basis or the momentum basis is to be "preferred" in order to break down the universal state vector into a set of eigenstates which you call "worlds" in DeWitt's version of the MWI.
You could take a look at this thread, and there's some discussion of the preferred basis problem starting on p. 9 of this paper. But you can find more references just by typing the words "preferred basis everett" (not in quotes) into google scholar or google books.
Hi JesseM, I'm reading old archive about the preferred basis problem and I came across the following post by Fredrik/wolverine in 2009. He said:
"There are always infinitely many bases to choose from. What decoherence does is (among other things) to single out one of them as "special"."
He said "infinite many bases". You mentioned only position and momentum. What others, how can it reach infinite? what weird combination is possible that can make it so numerous? pls give 10 examples of other bases beside our usual observables. Thanks
The following is from A. Neumaier site, one of the critique of Many Worlds. He wrote (what do
you think?):
Q8 When does Schrodinger's cat split?
******** As the cyanide/no-cyanide interacts with the cat the cat
******** is split into two states (dead or alive). From the surviving
******** cat's point of view it occupies a different world from its
******** deceased copy. The onlooker is split into two copies only
******** when the box is opened and they are altered by the states
******** of the cat.
Indeed, this confirms that splitting is a subjective process not
affecting the world at large. Otherwise the number of worlds could not
depend on the point of view? Or is it to be understood as follows:
As the cyanide/no-cyanide interacts with the cat the world is split
into two, one containig a dead cat and the other one that is alive?
And each of these two worlds splits again as the onlooker opens the box?
But then we have 4 worlds, two of which corresponding to nonexistent
possibilities (e.g., the world with the dead cat which is found alive
on opening the box). Thus only one split should have occured, and the
`explanation' is nonsense."
