Masses, pulley, friction and rotation
In summary, the equations given in the conversation are used to find the torque applied on a pulley in a system with four equations and five unknown variables. The equation (T2 + f - T1) = M*a2/2 describes the torque on the pulley, and can be simplified by considering the pulley and the section of string in contact with it as one system. This simplification is possible because the tensions in the vertical sections of rope do not act on the pulley, only the normal reactions and frictional forces between the string and the pulley. Finally, the equations can be further simplified by taking into account the massless string.
LCSphysicist
646
162
Two masses of 9 kg and 1 kg, hang from the ends of a string that passes around a pulley of mass 40kg and radius 0.5m (I=MR²/2) as shown in the diagram. The system is released form resst and the 9kg mass drops, starting te pulley rotating
If the coefficient of friction between the string and the pulley is 0.2 what is the least number of turns that the string must make around the pulley to prevent slipping?
All i cound find is:
T2-M2g = m2*a2
T1-M1g = -m1*a2
T2 = T1*e^(μ*θ)
In summarize, i have four equations and five incognits.
T2,T1,theta,a2,f
Need to find one more equation, but i don't know how
Please explain this equation. In particular, be precise about the subsystem it applies to.
Likes etotheipi
That equation says about the torque applied on the pulley, i adopt the system coordinates ordinary xyz with z pointing vertically.
assuming the friction force in the direction of my drawn, we have:
(T2*R + f*R - T1*R) = I*alpha = 0.5*M*R²*(a2)/R
We can cut R
T2 + f - T1 = 0.5M*a2
Friction in pulley questions can be a sightly slippery concept (you're welcome for the pun, I take payment in cash). This paper has a good rundown on the effect of friction at a pulley with a massless string. Section 4 is about torques in this context, which appears to be useful for your question.
The tensions themselves do not act on the pulley, only the normal reactions and frictional forces between the string and the pulley. Of these, only the frictional forces produce a torque about the axle. It turns out that the torque of all these frictional forces happens to equal the torque of the difference in the tensions on either side of the pulley.
As a "trick", you can also get the exact same result by considering the pulley + the section of string in contact with the pulley as one system, with ##T_1## and ##T_2## as the only external forces. This system would have the same moment of inertia as just the pulley, since the string is massless.
  • Love
Likes LCSphysicist
We can cut R
Let's distinguish three things here: the pulley, the section of rope in contact with the pulley and the vertical sections of rope.
The tensions in the vertical sections act on the contacting section; friction acts between the contacting section and the pulley. In other words, your f is not additional to T2-T1, it is the same thing.
Simplest is to think of the pulley and the contacting section of rope as a single entity.
  • Wow
Likes LCSphysicist and etotheipi
Wow from my country kkk NIvaldo Lemos has a book too.
I think i get it, so,
T2-M2g = m2*a2
T1-M1g = -m1*a2
T2 = T1*e^(μ*θ)
Become just
T2-M2g = m2*a2
T1-M1g = -m1*a2
(T2 - T1) = M*a2/2
T2 = T1*e^(μ*θ)
right?
it is just a little complicated to realize that the really important tension is only at the ends, is it a consequence of the rope not having mass?
I believe your adjusted equations are okay, though I'm falling asleep right now so I'll need to check them again in the morning 😅.
To understand why it works, you can either think of it in the way @haruspex mentioned (i.e. pulley + rope in contact with pulley as a system), or you can take a more complicated approach of integrating up the forces on the pulley due to lots of small elements of string. The torque relation is perhaps not an obvious result at first :wink:
Likes LCSphysicist
T2-M2g = m2*a2
T1-M1g = -m1*a2
T2 = T1*e^(μ*θ)
Become just
T2-M2g = m2*a2
T1-M1g = -m1*a2
(T2 - T1) = M*a2/2
T2 = T1*e^(μ*θ)
right?
Yes.
FAQ: Masses, pulley, friction and rotation
What is mass and how does it affect objects?
Mass is a measure of the amount of matter an object contains. It is a scalar quantity and is measured in kilograms. Mass affects objects by determining their inertia, which is the resistance of an object to changes in its state of motion.
How does a pulley work?
A pulley is a simple machine that consists of a wheel with a groove around its circumference and a rope or cable that runs through the groove. When one end of the rope is pulled, the wheel rotates and the other end of the rope moves in the opposite direction. This allows for the lifting or lowering of objects with less force.
What is friction and how does it affect motion?
Friction is the force that opposes the motion of objects that are in contact with each other. It is caused by the roughness of surfaces and the interlocking of microscopic bumps. Friction can either slow down or stop the motion of objects, or it can be beneficial by providing traction and allowing us to walk or drive on surfaces.
How does rotation affect objects?
Rotation is the circular movement of an object around a fixed point or axis. It affects objects by creating rotational motion and causing them to spin. This can affect an object's stability, balance, and angular velocity, which is the rate at which it rotates.
What is the difference between static and kinetic friction?
Static friction is the force that prevents two stationary surfaces from sliding past each other. Kinetic friction, on the other hand, is the force that opposes the motion of two surfaces that are already in motion. Static friction is typically greater than kinetic friction, as it takes more force to overcome the initial resistance of stationary objects.
