Maximum Energy transfer in Compton Effect
In summary, the conversation discusses the scattering of a photon with 14.7 keV energy from a free electron inside a metal. The participants discuss using the Compton equation to find the maximum energy the electron can gain from the photon, with a focus on finding the value of theta for which this energy is at its maximum.
PhatPartie
A photon having E = 14.7 keV energy scatters from a free electron inside a metal. What is the maximum energy the electron can gain from the photon?
Lamda'-lamda= change in lamda = h/mc (1-cos(theta)) ...having problems figuring out theta ... I know E=hc/lamda so lamda = hc/E ...so 1240eV/1.47*10^3 ev = .0843537 ...am i on the right track and if so where do i go from here? thanks
Find [tex] E_0 - E_1 [/tex] in terms of [tex]cos \theta[/tex] using compton equation.
See for what value of [tex] \theta [/tex], [tex] E_0 - E_1 [/tex] is maximum.
[tex] (E_0 - E_1)_{max} [/tex] is the maximum energy imparted to the electron.
Yes, you are on the right track. To find the maximum energy gained by the electron in the Compton effect, you need to use the equation: E' = E/(1 + (E/mc^2)(1 - cos(theta))), where E is the energy of the incident photon, E' is the energy of the scattered photon, m is the mass of the electron, and c is the speed of light.
In this case, the incident photon has an energy of 14.7 keV, so E = 14.7 keV. The mass of the electron is approximately 9.11 x 10^-31 kg and the speed of light is 3 x 10^8 m/s.
To find the value of theta, you can use the equation you mentioned, lambda' - lambda = h/mc (1-cos(theta)). Rearranging this equation, we get cos(theta) = 1 - (lambda'/lambda). Plugging in the values for lambda' and lambda, we get cos(theta) = 1 - (1.47 x 10^-10 m/1.24 x 10^-9 m) = 0.8823. Taking the inverse cosine of this value, we get theta = 30.4 degrees.
Finally, plugging in all the values in the equation for maximum energy transfer, we get E' = 14.7 keV/(1 + (14.7 keV/(9.11 x 10^-31 kg x (3 x 10^8 m/s)^2))(1 - cos(30.4 degrees))) = 14.7 keV/(1 + 5.93 x 10^-10)(1 - 0.8823) = 10.7 keV.
Therefore, the maximum energy the electron can gain from the photon is 10.7 keV. This shows that in the Compton effect, the maximum energy transfer occurs when the scattered photon is at a 90 degree angle from the incident photon.
Related to Maximum Energy transfer in Compton Effect
1. What is the Compton Effect and how does it relate to maximum energy transfer?
The Compton Effect is a phenomenon in which a photon (electromagnetic radiation) interacts with an electron, resulting in a change in the photon's wavelength and energy. Maximum energy transfer refers to the maximum amount of energy that can be transferred from the photon to the electron during this interaction.
2. What factors affect the maximum energy transfer in the Compton Effect?
The maximum energy transfer in the Compton Effect is affected by the angle of scattering between the photon and electron, as well as the mass and initial energy of the electron.
3. How is the maximum energy transfer calculated in the Compton Effect?
The maximum energy transfer in the Compton Effect can be calculated using the Compton formula: ΔEmax = h/mc(1 - cosθ), where h is Planck's constant, m is the mass of the electron, c is the speed of light, and θ is the angle of scattering.
4. Can the maximum energy transfer in the Compton Effect be greater than the energy of the incident photon?
Yes, the maximum energy transfer can be greater than the energy of the incident photon if the angle of scattering is large enough. This is because the kinetic energy of the scattered electron can also contribute to the total energy transfer.
5. What practical applications does the concept of maximum energy transfer in the Compton Effect have?
The concept of maximum energy transfer in the Compton Effect has practical applications in fields such as medical imaging, material analysis, and nuclear physics. It is used to determine the energy and direction of scattered photons, providing valuable information about the structure and composition of matter.
