Messing around with a function changes it's domain?
In summary: The conversation is discussing the manipulation of a function and its resulting changes to the domain. When taking a factor common in a function, the new function may not have the same domain as the original. This is because the manipulation may not be valid for all values of x, and in this case, it is not valid for x=0. This means that the factorization of the function is only valid for non-zero values of x and not for all real numbers. Additionally, dividing by zero is not allowed and can create non-sensical results. However, the function can still be defined at x=0 by taking the limit of the function as x approaches 0.
Swallow
messing around with a function changes it's domain??
consider a function f(x)= [tex]\sqrt[3]{2x^2-x^3}[/tex] if i take x^3 common from inside the cube root the function becomes f(x)= x*[tex]\sqrt[3]{2/x-1}[/tex]
the domain of the orginal function includes all real numbers, but the domain of the "new" function (which should technically be the same as the origiinal function) becomes all real numbers except zero...
What's going on?
EDIT: does this mean that taking a factor common changes the nature of the function itself?
Mathematics news on Phys.org
That factorization is only valid for non-zero x. If your manipulation had been valid for all x, e.g. factoring out the x^2, your resultant function would be well-defined on the whole domain. Technically the two functions you have are not equal.
It's all about that division by zero ain't allowed.
The two expressions, 2-x and x*(2/x-1) are not logically equivalent, because the latter contains the premise that x is non-zero,in order for the second factor to be a meaningful expression .
The first expression does not contain any such premise.
Hi jarle, if it's not valid for x^3, why should it be valid for x^2, how i see it, taking anything common from under the root is the same as multilying and dividing by that factor, so if i divide and multilpy by x^2, even then it shouldn't be valid for zero x as arlidno mentions, you still can't divide by zero
Note, however, that your factorized expression will have the same limit as x goes to zero as your first one!
As x becomes tiny, the term 2x^2 in your first expression will be much larger than the x^3-term, so that the function behaves as 2^(1/3)*x^(2/3) as x goes to zero.
In your second expression, 2/x will swamp the 1 in your second factor, so that your function will go as x*2^(1/3)*x^(-1/3), i.e, as your first one when multiplying together the powers of x.
Well, you don't need to "divide" with x^2.
2*x^2-x^3=x^2*(2-x) by the distributive property of multiplication, and this holds irrespective of the existence of the multiplicative inverse (which is what division requires).
Your reasoning in this case is that 1/0 is a factor of 0 which is simply non-sensical. x^2 = 1 * x^2 for all x, but x^2 = x^3 * 1/x only for non-zero x. So you see that you cannot factor your expression this way simply because it's not defined when x is 0. The factorization assumes that 1/x exists; as a rule of thumb you can never divide by 0. You can define the function at 0 by taking the limit of your function as x approaches 0 and still have your original function. However as it stands it is not defined at x = 0.
FAQ: Messing around with a function changes it's domain?
How does messing around with a function change its domain?
When we manipulate a function, we are essentially changing its rules and input values. This can result in a change in the function's domain, which is the set of all possible input values for the function. For example, if we add a restriction to the function, it may no longer be defined for certain input values, thus changing its domain.
Can changing a function's domain affect its range?
Yes, changing a function's domain can also change its range. The range of a function is the set of all possible output values for the function. When we modify the domain, we may also be limiting the possible output values, thus altering the range of the function.
How can I determine the new domain of a function after manipulating it?
To determine the new domain of a function, we need to analyze the changes made to the original function. If we added restrictions or removed certain values from the domain, we need to exclude those values from the new domain. We also need to consider any new rules or operations applied to the function and how they may affect the input values.
Is it possible to expand a function's domain?
Yes, it is possible to expand a function's domain. This can be done by adding new input values that were not previously allowed in the domain. For example, we can extend the domain of a function from just positive numbers to include negative numbers as well.
What are some common ways to change a function's domain?
There are several ways to change a function's domain, including adding restrictions, applying transformations, and combining multiple functions. Adding restrictions can limit the domain to a specific range of values. Transformations, such as shifting or reflecting the function, can also change its domain. Combining functions can create a new domain that is a combination of the input values from each individual function.
