Microwave Emitting Star, and detector with diffraction
In summary: TFMSorry for leaving you high and dry, but I see that Carid adopted my post. Also, sorry about that "method of images hint"; I had thought you might have been able to find it more broadly applicable than static, charged monopoles. I'll try to give it a different way. Have you studied flat mirrors, yet?
TFM
1,026
A microwave detector is located 0.5m above the surface of a large lake far from the shore. As a star, emitting monochromatic microwave radiation of 21cm wavelength, rises slowly above the horizon, the detector indicates successive maxima and minima in the signal intensity. At what angle above the horizon is the star when the first maximum is received?
Not sure of relevance:
Youngs:
[tex] I(s) = I_0 cos^2 \frac{kDs}{2} [/tex]
Infinite Grating:
[tex] I(s) = I_0 \sum^\{infty}_{n = -\infty}\sigma (s-\frac{n\lambda}{d}) [/tex]
I am slightly unsure about this question. My main problem is that I am unsure where the diffraction is coming from? Any help would be most appreciated.
Included is a diagram of my interpretation of the situation
Thanks in advance,
TFM
TFM said:
... detector ... located 0.5m above ... surface ...
... a star, emitting ... 21cm wavelength, rises ... above the horizon, ... detector indicates successive maxima and minima in ... intensity.
I can't see your image file yet, but I'll bet that there is no diffraction, but that there is reflection. What physics principle allows for the variation in intensity?
I wouldn't worry to much about the diagram, its one I did myself, and not my best.
I didn't think it would be diffraction, but is the only thing I could think of that gives maxima and minima.
I am probably missing out on something simple, but I can't think exactly what else would give maxima and minima (regularly any way - I do Astrophyics as well, so Dust clouds spring to mind otherwise, but that's not relevant with this question)
TFM
Diffraction does not give maxima and minima, but it usually leads to another phenomenon that does. Anyway, like I said, it probably isn't diffraction. You need to read your book to find out what physical phenomenon I'm talking about. Consider two waves, and what happens when they try to occupy the same space.
Ah Interference - I feel so silly for not thinking of it sooner.
Would that not need two sources though?
TFM
EXCELLENT question! Hint: method of images. Oh, yeah, don't neglect phase changing behavior at material interface.
I don't think I have studied Method of Images?
This seems like an optics question - trouble is, I didn't do Optics (1st Year Astrophysics didn't do that course, only Theoretical, and non-Astro) - This question is from a 'Skills' Course.
TFM
Looked up Method of Images, and it seems to be about electric charges?
TFM
Any helpful ideas?
TFM
It's so romantic to see the moon reflected in the surface of a lake. Pity it doesn't emit much in the way of microwaves.
It is indeed.
But wouldn't the reflected waves be going upwards, and, although they would interfere with the incoming waves, they wouldn't reach the detector interfered - the incoming waves are only interfered whilst the other waves are there?
TFM
In a harbour you'll see a wave bouncing off the quay and interfering with any other wave that happens to be about. The microwaves beaming down from the star behave in much the same way.
We'll get our first maximum when the path lengths differ by a single half wavelength; only half because of the phase inversion at the water surface.
I reckon the star will be 6 degrees above the horizon.
Okay. So what sort of equations might be useful? This is supposed to be a big question, so I am assuming there is quite a few bits of work involved in getting out the right answer?
TFM
Draw one ray from your star to the detector.
Draw another arriving at the detector after being reflected at the lake surface.
Add in the information about the path length difference.
Do a bit of trigonometry.
Find angle.
Okay so (when it is accepted), is this the right sort of diagram?
TFM
That's okay
I didn't do optuics, so no, I don't believed I have studied much on flt mirrors. I nknow snells law, and that the anlge of incidenc = angle of reflection, although that isn't shown well on the diagram.
TFM
TFM said:
... I don't believed I have studied much on flt mirrors.
We're in more trouble than I thought. Do you have a freshman physics book with a chapter on mirrors and a chapter on wave phenomena?
I Know, I can't spell flat!
We have a result. I have a textbook, University Physics, and it has FOUR chapters dedicated to optics :approve:
Including one on interference and one chapter section on reflection (and refraction) on a plane surface, and on a sphereical surface.
Having a look...
Law of reflection:
[tex] \theta_a = \theta_b [/tex]
where these are the angles that the light hits and is reflected (assuming non perpendicular) - this is what a stated in a previous post.
Also, destructive interference:
[tex] r_2 - r_1 = (m + \frac{1}{2})\lambda , (m = \pm1, \pm2, \pm3...) [/tex]
Are these useful? I think they maybe...
TFM
TFM,
I'm fairly new in these parts and it seems I have transgressed the unwritten law in barging into a thread where someone else was already trying to help. Is that the way it works?
By the way, did you find anything incorrect or misleading in the contributions I made?
Your help was most useful.
Doe the equations above look good? (I am starting to get worried, since this is due in tomorrow at Midday! :eek: :eek:)
TFM
TFM
Another error on my part. i should have addressed the previous message to turin.
You diagram of the lake looked about right. The rays arrive parallel from a distant star (all stars are distant even the Sun!). Imagine a point somewhere on the lake where the upper ray is 1 metre above the water and the lower ray is reflected in the water, undergoing a phase change. The upper and lower ray paths from this point to the final object (50 cm high) are the same. Now the surface phase change effectively gives us a half wave length difference. So for a first maximum the path from the star to the water must be half a wavelength longer than the path from the star to the 1 metre high point. So we construct a right angled triangle. The hypotenuse is the one metre height. The base is half a wavelength long (11.5cm). So the angle theta at the top of the triangle, which is equal to the angle of the star above the horizon is given by sin theta = 11.5cm/100cm; this give us a value of 6.6 degrees for the angle.
Is that all you really need to do? It seems so simple, yet this is suppose to be the harder question!
TFM
The hard thing is to get a feel for the physics. Plugging numbers into equations is what you do when you understand what they mean!
Hey, supplementary question; how far is that 1 metre line from the 50cm post?
Well, it would be, using trigonometry,
[tex] 50*tan(90 - \theta) [/tex]
TFM
Yes, which is about 4m32cm or about 20.6 times the wavelength.
Out of interest, is the 1 metre an arbitrary number, or is there a specific reason this number was chosen?
Take a look at my new diagram and tell me how tall the dotted line should be.
I can't see the diagram yet,, but ill look as soon as it is on.
Also, is the phase change as it reflects due to the fact that its going from a low density medium to high density medium, and some of the wave is reflected and some transmitted, like so:
http://www.kettering.edu/~drussell/Demos/reflect/reflect.html
(near the bottom)
Makes sense to me.
TFM
Carid said:
TFM
The wavelength is 21cm, making half a wavelength 10.5 cm, not 11.5cm. will this effect the 1m (I still can't see the diagram yet)
TFM
  • #31
Well done, you spotted my "deliberate mistake"...gulp...So what is the proper value for angle theta?
  • #32
It would be:
[tex] \theta = asin(10.3/100) [/tex]
Which gives the angle to be: 5.9 degrees.
Does this look okay?
  • #33
10.3 ? I'm not the only one making "deliberate mistakes" this morning...
  • #34
Should be 6.02 degrees.
Silly Me! :cry:
TFM
  • #35
Have we made an error - I think we have found the minima, but the question asks:
TFM
