TMO
- 45
- 1
[PLAIN]http://www.smartphysics.com/images/content/mechanics/ch15/momentofinertia2new.png
What is the moment of inertia of the object about an axis at the center of mass of the object? (Note: the center of mass can be calculated to be located at a point halfway between the center of the sphere and the left edge of the sphere.)
mrod (hence denoted as mr) = 7.11 kg
msphere (hence denoted as ms) = 35.55 kg
rrod (this is the length of the rod, and it will hence be denoted as rr) = 5.8 m
rsphere (this is the radius of the sphere, hence denoted as rs) = 1.45 m
[tex]I = I_{center of mass} + md^2[/tex] (parallel axis theorem)
[tex]I_{sphere} = \frac{2}{5}mr^2[/tex]
[tex]I_{rod at end} = \frac{1}{3}ml^2[/tex]
I figured that the moment of inertia must include both the moment of a rod spinning at its edge and the moment resulting from the parallel axis theorem. This leads to the first part.
[tex] \frac{1}{3}m_r(r_r)^2 + m_r(r_s/2)^2 [/tex]
Doing something similar to the sphere gives a similar equation
[tex] \frac{2}{5}m_s(r_s)^2 + m_s(r_s/2)^2 [/tex]
Then I just combine these together, if the hyperphysics page is anything to go by (http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html). This yields the following.
[tex] \frac{1}{3}m_r(r_r)^2 + m_r(r_s/2)^2 + \frac{2}{5}m_s(r_s)^2 + m_s(r_s/2)^2[/tex]
However, this isn't correct. Why is this, and how can I fix this?
