Moment of inertia of a cylinder
In summary, the conversation discusses the derivation of the moment of inertia for a solid cylinder, with the formula I=∫ r2 dm and dm=dv *density. To arrive at the correct formula I=1/2mr2, it is necessary to use the equation dv=2πrh*dr instead of dv=\pir2h as in volume=cross-sectional area*height. The conversation also emphasizes the importance of considering density in the calculations.
gboff21
50
I have been deriving the moment of inertia of a solid cylinder and have got this far:
I=∫ r2 dm
and dm=dv *density
h=height
r=radius
[tex]\rho[/tex]=density
To get to the correct I=1/2mr2. you need to make dv=2[tex]\pi[/tex]rh dr
why isn't it dv= dv=[tex]\pi[/tex]r2h
Consider a circle on the end of the cylinder at radius r. If it goes all the way through the circle, its area is 2πrh. Let dV be this area times an incremental radius, dr:
dV = 2πrh*dr
Imagine it "unrolled" into a rectangular solid to see it clearly.
Don't forget the density.
Thanks I've been struggling to get my head round that for a while!
Most welcome. Always draw a picture!
Your derivation of the moment of inertia of a solid cylinder is correct. The reason why dv is not equal to \pi r^2 h is because dv represents an infinitesimal volume element, while \pi r^2 h represents the total volume of the cylinder. In other words, dv is a very small volume element, while \pi r^2 h is the total volume that is made up of many dv elements. When calculating the moment of inertia, we need to consider the distribution of mass throughout the entire volume, which is why we use dv instead of \pi r^2 h.
FAQ: Moment of inertia of a cylinder
What is moment of inertia of a cylinder?
The moment of inertia of a cylinder is a measure of its resistance to rotational motion. It is a physical quantity that describes how difficult it is to change the angular velocity of the cylinder.
How is the moment of inertia of a cylinder calculated?
The moment of inertia of a cylinder can be calculated using the formula I = 1/2 * m * r^2, where I is the moment of inertia, m is the mass of the cylinder, and r is the radius of the cylinder.
What factors affect the moment of inertia of a cylinder?
The moment of inertia of a cylinder is affected by its mass, shape, and axis of rotation. A cylinder with a larger mass or a larger radius will have a higher moment of inertia. The moment of inertia also varies depending on whether the cylinder is rotating about its central axis or a different axis.
How does the moment of inertia of a hollow cylinder differ from that of a solid cylinder?
The moment of inertia of a hollow cylinder is larger than that of a solid cylinder with the same mass and radius. This is because the mass of a hollow cylinder is distributed further from the axis of rotation, resulting in a higher resistance to rotational motion.
How does the moment of inertia of a cylinder affect its rotational kinetic energy?
The moment of inertia is directly related to the rotational kinetic energy of a cylinder. A larger moment of inertia means that more energy is required to change the rotational speed of the cylinder. This is why objects with a higher moment of inertia, such as a spinning top, tend to rotate more slowly than objects with a lower moment of inertia, such as a spinning coin.
