Moment of inertia: off-central diameter
In summary, the conversation revolves around calculating the moment of inertia (MoI) needed to rotate a cylinder of a given mass, diameter, and length around a pivot point that is off-center. The question is whether the MoI can be calculated using the central diameter equation or if the general formula needs to be used. The conversation also discusses the specific measurements and weight distribution of the cylinder, as well as the purpose of these calculations for a DIY motorized camera arm. In conclusion, the final calculation estimates that a motor with a rated torque of 50kg-cm would be sufficient for moving the arm at speeds up to 25RPM.
alevesque
Question for the brilliant minds around here:
I'm trying to figure the amount of torque (I*a) needed to rotate a cylinder of a given mass, diameter and length around a pivot point that is off-center. Typically I'm assuming I would find it out by calculating both I for central diameter and end diameter, and then multiply the off-center percentage by the difference between Icentral and Iend... Right?
Anyhow, here's the catch:
The cylinder CoG is at the pivot point (the cylinder is heavier on one end, and the pivot point is positioned so that it's perfectly balanced). I've been working off the assumption that I could simply use the central diameter equation to find the moment of inertia, since the weight is equally balanced, but I'm not sure...
So if the cylinder is 120cm long, and the pivot point is at 90cm, knowing that both end (long and short) are exactly 2.5kg, can I calculate the MoI using the central diameter equation with 120cm of length, or should I use the length of the longer end*2 (180cm) ?
That changes the torque requirements quite significantly, so any help would be immensely appreciated!
PS: I'm referring to the formulas to calculate the Moment of Inertia from Hyperphysics - Moment of Inertia: Cylinder
Thanks much!
-A
You can't make that assumption because the local contribution to the moment of inertia depends on the square of the distance from the axis of rotation. You need to calculate the moment of inertia from the general formula. (Integrate dI = density*distance^2*dV over the volume)
Can you be more specific about where precisely the axis of rotation is, and confirm that your cylinder is three-dimensional? (you didn't specify a radius).
Thank you for your reply!
Yes, the cylinder is three-dimensional; with roughly 7.5cm radius.
It is 1 meter long (I decided to shorten it, to ease the choice of motor), and weight 5kg - but most of the weight is on one end, so that when it is supported on a central pivot point located at 75cm from one end (3/4), it is perfectly balanced.
I've used:
I = (Mr2)/4 + (ML2)/12 to get the MoI - which would be correct if the cylinder mass was consistent across its length and the pivot point was central, but since both are offset equally, I was hoping it would get me in the same ballpark?
To put it in context, it is a small, lightweight DIY motorised camera arm that I'm putting together. The camera is on a mini pan/tilt head at one end, the pivot point is offset to allow as much travel distance as possible and counter-weight is added at the other end of the arm to keep it balanced. I'm going through these calculation to find out the torque needed for the motor on the arm axis to get decent speed...
Thanks a lot!
Ah. I've found your formula and the derivation. I'm fairly sure the result is different for your specific cylinder. What matters is not only the lengths and the weights, but the positions of the weights along the rod. For example, if you have a rod with a camera on one end plus a counter-weight on the other end, it's a lot easier to calculate the moment of inertia by adding the three individual mass contributions than to model the rod as a solid cylinder with variable density.
Eg.
Part 1: calculate the moment of inertia of the uniform density rod first. You can use your formula to calculate the MOI of a 1.5m rod from the centre, and also a 50cm rod from the centre. So if you work out the MOI of a 1.5m version (with central pivot), subtract the MOI of a 0.5m version (with central pivot), and divide by 2, you will end up with the contribution to the MOI of the rod from the 50cm section which is most distant from your pivot. Add this to the 0.5m calculation and you've got your answer, for a uniform density rod!
Part 2: simply add the counterweight/camera masses together. Eg. if your camera weighs 1kg and it is 75cm from the pivot, its contribution is 1*0.75^2. Same with the counterweight.
So the thing as a whole can be calculated using a series of symmetry tricks, due to the additive nature of the moment of inertia.
Amazing!
Thanks much Mikey. Just to sum it up - and to make sure I understood correctly - here's my process:
Assumptions:
The arm is 1m long, has a radius of 7.5cm and a mass of 1Kg.
A camera weighting 1Kg is attached on one end, and a 3Kg counter-weight is attached on the other end.
The arm can pivot around an axis located 75cm from the camera - at the CoG. A motor must be able to move it at up to 25RPM.
Calculations:
First, the MoI of the arm alone; using cylinder equation for the long and short ends:
I=(Mr2)/4 + (ML2)/12;
Long end: (1*0.0752)/4 + (1*1.52)/12 = 0.1889
Short end: (1*0.0752)/4 + (1*0.52)/12 = 0.0222
Substract short end from long end, and divide by 2: (0.1889-0.0222)/2 = 0.0834
Add short end contribution: 0.0834 + 0.0222 = 0.1056
Camera & counterweight contributions:
Camera (1Kg @ 75cm): 1*0.752 = 0.5625
Counterweight (3Kg @ 25cm): 3*0.252 = 0.1875
Total I for the arm with camera & counterweight: 0.1056 + 0.5625 + 0.1875 = 0.8556
If the above is correct, then in order to move it at 25RPM:
25 RPM == 2.618rad/s
T = I*a; so 0.8556*2.618 = 2.24
2.24Nm == 22.842 Kg-cm
All the provided measures are approximate, and this does not take into account the bearing friction and other forces - but is it safe to assume that a motor with a rated torque of 50kg-cm (doubling for comfortable margin) would have no problems moving the arm around at speeds up to 25RPM?
Thanks again for your help...
-A
FAQ: Moment of inertia: off-central diameter
What is moment of inertia: off-central diameter?
The moment of inertia: off-central diameter is a measure of an object's resistance to rotational movement around an axis that is not located at the center of mass. It takes into account the distribution of mass around the axis of rotation.
How is moment of inertia: off-central diameter different from moment of inertia?
The moment of inertia: off-central diameter differs from the regular moment of inertia in that it considers the distance of each particle of mass from the axis of rotation, rather than just the mass itself. This makes it a more accurate measure of an object's rotational inertia.
How is moment of inertia: off-central diameter calculated?
The moment of inertia: off-central diameter can be calculated by multiplying the mass of each particle in an object by its distance from the axis of rotation squared, and then summing these values for all particles in the object. This calculation can be represented by the formula I = Σm(r^2).
What are the applications of moment of inertia: off-central diameter?
Moment of inertia: off-central diameter is an important concept in rotational dynamics and is used in many engineering and physics applications. It is used to calculate the stability and performance of rotating objects such as wheels, gears, and propellers. It is also used in designing and analyzing machines and structures that involve rotational motion.
How does the off-center diameter affect an object's moment of inertia?
The off-center diameter has a direct impact on an object's moment of inertia. The farther the mass is from the axis of rotation, the larger the moment of inertia will be. This means that objects with a larger off-center diameter will have a greater resistance to rotational motion than objects with a smaller off-center diameter.
