kaspis245
- 189
- 1
A quadratic frame which has an edge of ##a=10 cm##, was put inside a magnetic field ##B=0.01T##. The frame's opposite vertices were being pulled with a uniform speed ##v=1mm/s## until the frame became flat. Find the charge that passed through the frame. The plane of the frame remained perpendicular to the magnetic field all the time, the resistance of the frame equals ##R=5Ω##.
##ε=vLB##
##I=\frac{q}{t}##
##ε=IR##
Here's my try:
Clearly the answer I get is incorrect, because ##v## does not appear in the final formula. How should I approach this problem?
