My notes for this chapter suck, so I
  • Thread starter billbennett770
  • Tags
    Notes
Write it all out and then see if you can cancel out or simplify anything.Not as well I thought I did, or at least not how it pertains to continuous proability density.It seems like you may need to review the concept of probability and how it applies to continuous probability density functions. In this case, the probability of a certain outcome (represented by the pdf) occurring on a specific interval of x is equal to the area under the pdf curve on that interval. This is why we use integrals to find probabilities for continuous random variables. I would recommend reviewing examples and practice problems to get a better understanding of this concept.
billbennett770
Given the continuous probability density function f(x) = (x-2)/18 2 ≤ x ≤ 8, find P(6<x≤8)?
For a continuous random variable, if you have a pdf f(x) on the interval a to b,
P(c≤x≤d)=∫dcf(x)dx
E(X)=μ=∫baxf(x)dx
Var(X)=∫ba(x−μ)2f(x)dx
For this problem, you are given with pdf f(x) and the interval is given. So you need to evaluate the integral.
∫baf(x)dx= ∫8,2((x-2)/18))... I honestly lose it from here.
##f(x)=\frac{x-2}{18}: 2\leq x \leq 8##
You have to evaluate: $$p(6<x\leq 8)=\int_6^8 \frac{x-2}{18}\; dx$$ ... you had the wrong lower limit.
Show me your best attempt from there.
P(c≤x≤d)=∫dcf(x)dx
E(X)=μ=∫baxf(x)dx
Yes, your notes are a mess. Let's see if we can straighten things out.
For this problem, the expectation E(x) and the Variance Var (x) are not required.
You are given a certain probability density function (pdf) and asked to find the probability that x will lie between 6 and 8.
The cumulative density function (cdf) is the integral of the pdf from -∞ to +∞ and by definition:
[itex]\int^{∞}_{-∞}[/itex][pdf (x)] dx = 1
This is not a difficult integral to evaluate since your pdf = 0 except between x = 2 and x = 8.
You should check your pdf to make sure that the relation above is satisfied.
Since the area of the pdf over the entire range of x is 1, this means that all possible outcomes of whatever the pdf represents have occurred. If you want to find the probability of occurrence of whatever is represented by the pdf on a certain interval of x, you would take the integral of the pdf between the limits of that interval.
okay then. From P(6<x≤8)
∫ f(x) dx = ((x²/2) -2x)/18
at x = 6 : ((6²/2) -2*6)/18= (18 -12)/18 = 1/3
at x = 8 : ((8²/2 -2*8)) = ((32 -16))/18 = 16/18 = 8/9
: 1/3 < P(6<x≤8) ≤ 8/9
Not as well I thought I did, or at least not how it pertains to continuous proability density. First, I am really perplexed why I am given 2 ≤ x ≤ 8 --or is this just another way of saying [2, 8]? Also, how do you evaluate P(6 <x ≤8)? I have only done int he past when the question employs both ≤ and , as in P(6 ≤x ≤8).
For example, here is a previous question I did:
Is f(x) 2/(x^2) on [1,2] a probability density function? Why or why not? If it is, find P[1.5 ≤ x ≤ 2]
∫ba f(x)dx = 2,1 2/(x^2) dx = [-2/x] 2, 1 = -1+2=1
So yes because it is postive.
∫1,5,2 (-2/x) = 1/3
So it it just (8/9) - (1/3)
Exactly the same as it does to anything.
That just means that f(x) is defined on that interval.
What is ##p(2\leq x\leq 8)## - evaluate it.
Yes. ##x\in (2,8]## is the same as saying ##2<x\leq 8##
The probability is the area under f(x) inside the range. The difference in area inside a<x<b and inside a<x≤b is zero. Sketch it out for a bunch of arbitrary functions and see.
There you go.
FAQ: My notes for this chapter suck, so I
What should I do if my notes for this chapter are inadequate?
If your notes for this chapter are not sufficient, the first step is to review the material again. It may also be helpful to seek clarification from your teacher or peers. If necessary, you can also supplement your notes by finding additional resources, such as online lectures or textbooks.
How can I improve my note-taking skills?
Note-taking is a skill that can be learned and improved upon. Some tips for better note-taking include actively listening and engaging with the material, using abbreviations and symbols, and organizing your notes in a way that makes sense to you. Practice and experimentation can also help you find the note-taking style that works best for you.
What should I do if I can't keep up with taking notes during a lecture?
If you find yourself unable to keep up with taking notes during a lecture, consider recording the lecture to review later. You can also ask the teacher for their notes or slides, or ask a classmate to share their notes with you. Additionally, try to identify the most important information and focus on taking notes on that instead of trying to write down everything.
Is it okay to use someone else's notes?
Using someone else's notes can be helpful in supplementing your own notes or filling in any gaps. However, it is important to make sure you understand the material and not simply copy someone else's notes without comprehension. It is also important to give credit to the original source if you use someone else's notes.
What are some common mistakes to avoid when taking notes?
Some common mistakes to avoid when taking notes include writing down too much information, not organizing your notes in a way that makes sense, and not reviewing your notes regularly. It is also important to avoid just copying information without understanding it and not taking breaks during longer lectures or study sessions.
