Name of a switch that alternates between two states.
In summary, the name for a switch that alternates between two states when depressed is an SPST push-on push-off push button switch, also known as a latching pushbutton switch. It can be purchased from online retailers such as Amazon and Digikey, where there are options to filter for specific ratings. Some switches may have a minimum quantity requirement, so be cautious when making purchases. The term "reciprocating" has also been used to describe this type of switch.
balsaboom
I'm wondering what the name of a switch that alternates between two states only when depressed. An example would be a flashlight, where if you click it once, it turns on, and if you click it off, it turns off (no need to hold down the button to get a continuous light).
thanks!
i think I've seen the adjective "reciprocating" used for that kind of switch.
FAQ: Name of a switch that alternates between two states.
What is a "Name of a switch that alternates between two states"?
"Name of a switch that alternates between two states" is a term used to describe a type of electrical switch that has two possible positions or states. It is also commonly referred to as a "toggle switch" or "on-off switch".
How does a "Name of a switch that alternates between two states" work?
A "Name of a switch that alternates between two states" typically consists of a lever or button that can be moved or pressed to change its position. This physical movement triggers the switch to change between its two states, allowing or interrupting the flow of electricity.
What are the common uses of a "Name of a switch that alternates between two states"?
"Name of a switch that alternates between two states" is commonly used in a variety of electronic devices and appliances, such as lamps, fans, and household appliances. It can also be found in industrial settings, such as in machinery or control panels.
How is a "Name of a switch that alternates between two states" different from other types of switches?
A "Name of a switch that alternates between two states" is different from other types of switches, such as push-button or rocker switches, because it only has two possible states, whereas other switches may have multiple positions or functions. It also requires physical movement to change between its two states, rather than just pressing a button or flipping a switch.
Can a "Name of a switch that alternates between two states" be used in circuits with varying voltages?
Yes, a "Name of a switch that alternates between two states" can be used in circuits with varying voltages as long as it is rated for the voltage and current of the circuit. It is important to choose the correct switch for the specific application to ensure safe and proper functioning.
