Need a glue that will withstand 250°C or 350°C
  • Thread starter 0xDEADBEEF
In summary, a glue that can withstand high temperatures and be removed later is needed for reflow soldering.
0xDEADBEEF
816
To fixate some tiny wires for reflow soldering I need a glue that will withstand 250°C or 350°C and can be removed later. It should also not "sweat" or dissolve in tin so the solder stays clean.
I have thought about gypsum (plaster) and I hope it's removable with acid. But I fear it will get crumbly, isn't sticky enough and not nice to use.
Do you have any suggestions? I am sure there must be something water based. If salt would only be more sticky, and sugar wouldn't burn...
Being common in chemistry labs would be a plus, but not a prerequisite.
Chemistry news on Phys.org
What sort of surface are you trying to stick the wires to?
The surface matters little to me since it is just supposed to support the structure while soldering. The insulation materials involved are sapphire and capton, the contacts are gold.
I would not call plaster acid soluble.
High-temperature silicone or PDMS (poly dimethoxysilane--silicone for micro/nanofabrication types)? Especially if you let it mould around whatever it is you're trying to hold in place.
To dissolve it, there are a few products on the market that might work that you can find in your local hardware store (DAP Silicone-Be-Gone can be found at Home Depot and Rona if you're in Canada) which I've never used. But for PDMS, there's a product called Dynasolve that works wonders for some friends / colleagues of mine.
There's a product from MG Chemicals that's meant for stripping various conformal coat / potting / encapsulation chemicals (of various compositions):
http://www.mgchemicals.com/products/8310.html
Either way, I'd advise you to test it out on, say, a glass slide or something before doing it for real (the application of the adhesive, temperature treatment, and then subsequent attempt at strip).
That sounds promising. The temperature is still a little low. It seems anything breaks down at 260°C the latest, but I can probably tweak a bit with the flux.
FAQ: Need a glue that will withstand 250°C or 350°C
What type of glue can withstand high temperatures?
There are several types of adhesives that can withstand temperatures up to 250°C or 350°C, such as silicone-based glues, ceramic adhesives, and high-temperature epoxy adhesives.
Can regular glue withstand high temperatures?
No, regular glue is not designed to withstand high temperatures and will likely melt or lose its bond at temperatures above 150°C.
How do I know if a glue can withstand 250°C or 350°C?
You can check the manufacturer's specifications or product label to see the maximum temperature resistance of the glue. Additionally, it is important to choose a glue that is specifically designed for high-temperature applications.
Can high-temperature glue be used on all types of materials?
No, some high-temperature glues may only be suitable for certain materials, such as metal or ceramic. It is important to read the product instructions and choose a glue that is compatible with the materials you are working with.
How should high-temperature glue be applied?
High-temperature glue should be applied in a well-ventilated area and with the proper safety precautions, such as wearing gloves and eye protection. It is also important to follow the instructions for mixing and curing the glue for best results.
