Need help on Motion in a Resistive Medium
In summary, the conversation discusses the motion of a body falling from rest in a resistive medium, represented by the equation dv/dt = Bv - Av^2. The initial acceleration and velocity at which the acceleration becomes zero are also mentioned, along with the fact that B and A are constants. However, the equations cannot be used to solve the problem as they only apply to uniform acceleration.
eyvhgi557r
1. The motion of a body falling from rest in a resistive medium is dv/dt = Bv - Av^2.
2. Find it's initial acceleration.
Find the velocity at which the acceleration becomes zero.
3. B and A are constants.
dv/dt = acceleration = Bv - Av^2.
vf = vi + at
vf = 0 + Bv - Av^2(t)
vf = Bv - Av^2(t)
Where am I going with this?
Hi eyvhgi557r! :smile:
vf = vi + at
vf = Bv - Av^2(t)
hmm … nowhere! :rolleyes:
those equations only apply to uniform acceleration …
you need to solve dv/dt = Bv - Av^2 in the usual way. :smile:
FAQ: Need help on Motion in a Resistive Medium
What is motion in a resistive medium?
Motion in a resistive medium refers to the movement of an object through a substance or environment that resists its motion. This resistance is caused by factors such as friction, drag, or viscosity.
What is the difference between motion in a resistive medium and motion in a vacuum?
In a vacuum, there is no resistance to an object's motion, so it will continue to move at a constant velocity. In a resistive medium, the object will experience a decrease in velocity over time due to the resistance of the surrounding environment.
How does the mass and shape of an object affect its motion in a resistive medium?
The mass and shape of an object can greatly impact its motion in a resistive medium. A larger and heavier object will experience more resistance, while a more streamlined shape can reduce resistance and allow for a smoother motion.
What are some examples of motion in a resistive medium?
Some examples of motion in a resistive medium include a ball falling through air, a boat moving through water, and a car driving through a windy environment. These all experience resistance from the surrounding medium that affects their motion.
What are some applications of studying motion in a resistive medium?
Understanding motion in a resistive medium is important in fields such as aerodynamics, fluid mechanics, and vehicle design. It can also help in predicting the behavior of objects in different environments, such as spacecraft in outer space or fish swimming in water.
