Need help regarding heat transfer questions
In summary, the conversation is about calculating different aspects of heating systems using given values such as heat sources, water flow rates, and temperatures. The first question involves determining the time it takes to heat a 500 litre hot water cylinder to 60°C using a 30kW primary heat source and a 12°C inlet water temperature. The second question asks for the mass flow rate of a plate heat exchanger with a 400kW rating, given an inlet temperature of 85°C and an outlet temperature of 40°C. The final question is about finding the temperature of water entering a heat exchanger to achieve a water flow rate of 5kg/s from a 210kW heat source at 20°C.
wattsie10
Please can someone show me how to work out the following questions.
1) A hot water cylinder holds 500 litres. If the primary heat source is 30kW and the supply water inlet to the cylinder is 12°C, how long will it take to heat the whole tank to 60°C?
2) The primary side of a plate heat exchanger rated at 400kW has an inlet temperature of 85°C and the outlet temperature is 40°C. What is the mass flow rate?
3) To achieve a water flow rate of 5kg/s at 20°C from a 210kW source, what would be the temperature of the water as it enters the heat exchanger?
Many thanks
Welcome to PF!
Hi wattsie10! Welcome to PF! :wink:
Show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
for reaching out for help with your heat transfer questions. I understand that these problems can be challenging, but with the right approach and understanding of heat transfer principles, they can be solved easily.
For question 1, we can use the formula Q = mcΔT, where Q is the heat energy, m is the mass of water in the cylinder, c is the specific heat capacity of water, and ΔT is the change in temperature. We know that the heat energy supplied (Q) is 30kW, the mass (m) is 500 litres, and the change in temperature (ΔT) is 60°C - 12°C = 48°C. We can convert the volume of water to mass using the density of water (1 liter = 1kg). Solving for time (t), we get:
Q = mcΔT
30kW = (500kg)(4.18 kJ/kg°C)(48°C)
t = 5.09 hours
Therefore, it will take approximately 5.09 hours to heat the whole tank to 60°C.
For question 2, we can use the formula Q = mcΔT, where Q is the heat energy, m is the mass of water in the heat exchanger, c is the specific heat capacity of water, and ΔT is the change in temperature. We know that the heat energy supplied (Q) is 400kW, the inlet temperature (T1) is 85°C, and the outlet temperature (T2) is 40°C. Solving for mass (m), we get:
Q = mcΔT
400kW = (m)(4.18 kJ/kg°C)(85°C - 40°C)
m = 14.83 kg/s
Therefore, the mass flow rate is 14.83 kg/s.
For question 3, we can use the formula Q = mcΔT, where Q is the heat energy, m is the mass of water in the heat exchanger, c is the specific heat capacity of water, and ΔT is the change in temperature. We know that the heat energy supplied (Q) is 210kW, the flow rate (m) is 5kg/s, and the inlet temperature (T1) is what we need to find. Solving for ΔT and T1, we get:
Q = mc
FAQ: Need help regarding heat transfer questions
What is heat transfer?
Heat transfer is the movement of thermal energy from one object or system to another due to a temperature difference. It can occur through three main mechanisms: conduction, convection, and radiation.
What are the factors that affect heat transfer?
The factors that affect heat transfer include the temperature difference between the objects, the thermal conductivity of the materials, the surface area of contact, and the distance between the objects.
Can you explain the difference between conduction, convection, and radiation?
Conduction is the transfer of heat through a solid or stationary material, while convection is the transfer of heat through a fluid or gas. Radiation is the transfer of heat through electromagnetic waves, such as from the sun.
How is heat transfer important in everyday life?
Heat transfer is an essential aspect of our daily lives. It is responsible for keeping our homes warm, our food cooked, and our bodies at a stable temperature. It also plays a crucial role in various industrial processes, such as refrigeration and heating systems.
How can I calculate heat transfer?
The amount of heat transferred can be calculated using the equation Q = mcΔT, where Q is the heat transferred, m is the mass of the object, c is the specific heat of the material, and ΔT is the change in temperature. This equation applies to conduction and convection, while radiation can be calculated using the Stefan-Boltzmann law.
