Need to ask this question again
  • Thread starter Jamin2112
In summary, the need to ask a question again can arise due to various reasons, such as not understanding the answer, needing clarification, or simply forgetting the answer. Repeating a question can also be a helpful strategy for retaining information and gaining a deeper understanding of a topic. However, it is important to consider the context and the recipient when deciding whether to ask a question again. Asking the same question multiple times can be perceived as annoying or disrespectful, so it is important to use this approach carefully and respectfully.
Jamin2112
986
A few days ago, I asked about the continuity of a function, in regards to a problem on my homework. Something still seems wrong, even though today my professor insisted that the given definitions are correct. Look here: http://www.math.washington.edu/~sullivan/3261_sp10.pdf"
A function f(x,y) is continuous at a point (x0,y0) if f(x,y) is defined at (x0,y0), ...
A function f(x,y) is discontinuous at a point (x0,y0) if f(x,y) is defined at (x0,y0), ...
So if a function isn't defined, then it is neither continuous or discontinuous?
According to those definitions, I'll agree. Yes, if it's not defined it's neither continuous nor discontinuous.
Weird
Jamin2112 said:
Weird
Well, think about f(x)=sqrt(x). That's only defined for x>=0. You certainly don't want to say it's continuous at x=(-1). And it also sounds a little weird to say it's discontinuous at x=(-1). It's just not defined. Not all that strange.
FAQ: Need to ask this question again
What does "Need to ask this question again" mean?
"Need to ask this question again" simply means that the question has already been asked before and the person asking it needs to repeat or clarify it.
Why do I need to ask this question again?
There could be a few reasons why you need to ask a question again. It could be because you didn't receive a clear answer the first time, you need more information, or you may have forgotten the answer.
How do I know if I need to ask a question again?
If you're unsure about the answer you received or if you don't fully understand the information, it's always best to ask the question again. It's better to be sure than to make assumptions.
Can I phrase the question differently instead of asking it again?
Yes, you can try rephrasing the question to see if you get a clearer answer. Sometimes, changing the wording can help clarify the information you're seeking.
Is it okay to ask the same question multiple times?
It's generally not recommended to ask the same question multiple times, especially if you've already received an answer. However, if you're still confused or need more clarification, it's okay to ask again but try to rephrase the question to avoid any confusion or frustration.
