Negative exponents and calculation rules
In summary: For example:\frac{5^1}{3}=\frac{5^0}{3}\frac{2^1}{3}=\frac{2^0}{3}\frac{3^1}{3}=\frac{3^0}{3}...and so on.I just want to know if a negative exponent is as just the same as saying one over another number.In summary, a negative exponent is the same as saying one over the whole number.
runicle
75
For example:
5^1/3 = 5^-3
Another thought
would base numbers only affect base numbers and exponents only affect exponents?
No, that is not right. To put it in your word: a negative exponent is the same as saying one over the whole number. In other words:
[tex]x^{-a}=\frac{1}{x^a}[/tex]
oops i meant to say
a negative exponent is as just the same as saying a base number to the power of one over a number
Anyway, it it still not correct. See my previous post.
That would be saying [itex]a^{-x}= \frac{a^1}{something}[/itex], wouldn't it?? That, of course, is wrong. Again
[tex]a^{-x}= \frac{1}{a^x}[/tex]
runicle said:
Another thought
Eeh? Come again?
This is just incomprehensible.
Just figured it out in the calculator,
Figured out what? Are you saying you now know how to simplify something like [itex]\frac{a^6}{a^{-4}}[/itex] or are you just saying you'll let your calculator do it for you?
No i just put 2^2 gave me an answer 2^1/2 gave me an answer 2^-2 gave me an answer and none of the answers were the same.
For example:
5^1/3 = 5^-3
Another thought
Specifically, [tex]5^{1/3}=\sqrt[3]{5}[/tex] and [tex]5^{-3}=\frac{1}{5^3}[/tex]
Not sure what you mean by your second question. Do you have an example in mind?
-Dan
It's not a question i just wanted to know the question previous to that dilemna had any way to relate to the dilemna. For even lamens terms:
1st part of first question.
2 over 3 is exactly the same as 4 over 6 only its simplified.
would 5^-3 be the same as 5^1/3? (Yes it does)
Another thought
In number 2*2 = 4, 2^2*2^2 = 2^4, you know what i mean... example of a problem.
3(2x*3) = 6x*9 notice 3 outside of the brackets affect the numbers inside of it? If the 2x was 2x^2 would it be then after 6x^6*9.
Sorry, my english. I am trying to improve on it, please correct my grammar if you can. (It was all a misunderstanding, lol)
No. 5^-3 = 0.008.
5^(1/3) = 1.70998
The reason they're different is because the exponents are different. If -3 does not equal 1/3 (it does not) then 5^-3 cannot equal 5^(1/3).
- Warren
No
3(2x*3) = 6x*3 you essentiall multiplied by 9. and let's say you have just x2 for a second if you multiply that by 3 you get 3x2 not 3x6 The exponent is unaffected because you don't know for sure if x = 3 or what x equals
No, you should know that:
[tex]\sqrt[n] {a ^ m} = a ^ {\frac{m}{n}}[/tex].
And:
[tex]a ^ {-m} = \frac{1}{a ^ m}[/tex].
This is due to:
[tex]\frac{a ^ m}{a ^ n} = a ^ {m - n}[/tex].
So:
[tex]a ^ {-m} = a ^ {0 - m} = \frac{a ^ 0}{a ^ m} = \frac{1}{a ^ m}[/tex]
Since a0 = 1 for all a <> 0.
Now, back to your problem:
[tex]5 ^ {\frac{1}{3}} = \sqrt[3] {5} \approx 1.71[/tex], whereas:
[tex]5 ^ {-3} = \frac{1}{5 ^ 3} = \frac{1}{125} = 0.008[/tex].
And of course you know that:
0.008 <> 1.71, right? :)
correct me if I'm wrong
Question=(2x+2)(3x+3)
-Foiled
=6x^2+6x+6x+6
=6x^2+12x+6
so...
3(2x+3) = 6x+9 (so side note to that) 3(2x*3)= 6x*3
so...
2^1/3 = 3v--2 and 2^-3 = 1/2^3 = 1/8
so...
can anyone give me some good ways of remembering this stuff? Or atleast tips?
Everything you've posted looks correct, runicle. I'd advise that you use the notation sqrt(2) instead of "v--2" to represent the square root, or use the latex features built into the site.
How to remember this stuff? Most of it becomes second nature once you being using it a bit. Which of your "operations" are you having trouble remembering?
- Warren
Do 30 problems and I would think that you would know every single thing without thinking about it anymore.
I am still a little fuzzy with what happens when you add, multiply exponents and what and what not can you add or multiply with. Like as an example 2x^2 + 2x can't be added... Do you catch my drift? Along with what you can and cannot do when doing certain tasks. Is there a very good website that can tell you right away what expressions or equations would bring you to know common tasks?
My suggestion is that you should go over your textbook again thoroughly, try to understand the concept, then try your hands on some problems, and remember the formulae.
[tex]a ^ x \times a ^ y = a ^ {x + y}[/tex]
[tex]\frac{a ^ x}{a ^ y} = a ^ {x - y}[/tex]
Now of course, you cannot "add" 2x2 + 2x to get 4x2 or 4x. Just think like this:
Writing 3x2 means that you have three x2's (it's like you have 3 apples), 5x2 means that you have five x2's. If you add them together, you'll have 8 x2's, right?
3x2 + 5x2 = 8x2.
Now 3x2 + 2x cannot be added since x is not the same as x2, you cannot add 3 apples, and 2 orranges, right? However, it can be factored like this:
3x2 + 2x = x(3x + 2).
Can you get this? :)
-Foiled
=6x^2+6x+6x+6
=6x^2+12x+6
Yes, that's correct.
so...
I wish you wouldn't use different symbols for the same thing!
Does (2x*3) mean the same as 2x^3? If so then both of those are correct.
so...
2^1/3 = 3v--2
It took me a while to figure that out! the v-- thing is a root!
Yes, [itex]2^{\frac{1}{3}}= ^3\sqrt{2}[/itex]. Click on that to see the LaTex code I used.
Yes, that also is true.
so...
The same way you get to Carnegie Hall- practice, practice, practice! Do lots of homework problems. If you teach assigns half the exercises on a page- do all of them!
I Barely have time to practice because i have kickboxing english homework law homework accounting homework and Math. So... If you tell me to forget about sleeping than I have no life... I wish there was a site That has everything about this kind of stuff organized, well presented and easy to remember. That would help everyone who has practically any time and just need a quick look at doing things like a minute an hour.
FAQ: Negative exponents and calculation rules
What is a negative exponent?
A negative exponent is a way of representing a fraction with a numerator of 1 and a non-zero denominator. It indicates that the base should be divided by itself a certain number of times, instead of multiplied by itself.
How do you calculate a negative exponent?
To calculate a negative exponent, you can either use the negative exponent rule, which states that x-n = 1/xn, or you can rewrite the exponent as a positive exponent by moving it to the denominator of a fraction with a numerator of 1.
Can a negative exponent be a whole number?
Yes, a negative exponent can be a whole number. For example, 2-3 = 1/23 = 1/8.
What is the rule for multiplying and dividing with negative exponents?
The rule for multiplying and dividing with negative exponents is to add or subtract the exponents, depending on the operation. For example, x-3 * x-2 = x-5 and x-3 / x-2 = x-1.
How do you apply the power rule with negative exponents?
The power rule for negative exponents states that (xm)-n = xm*n. This means that when raising a power to a negative exponent, you can multiply the exponent outside of the parentheses by the exponent inside the parentheses, and rewrite it as a positive exponent.
