Never ending integration by parts
In summary, the conversation discussed the integration by parts method and attempted to solve the integral \int_0^\infty{ \frac{1}{x} e^{-x}} using this method. However, it was determined that the integral cannot be reduced to a simple function and actually defines a special function called the exponential integral, Ei(x). Additionally, given the limits of zero to infinity, the integral diverges.
Smed
36
[tex] \int_0^\infty{ \frac{1}{x} e^{-x}} [/tex]
Integration by parts
[tex] \int{u dv} = uv - \int{v du} [/tex]
[tex] u = \frac{1}{x} [/tex]
[tex] du = \frac{1}{x^2} dx [/tex]
[tex] v = -e^{-x} [/tex]
[tex] dv = e^{-x} dx [/tex]
[tex] -\frac{1}{x} e^{-x} - \int_0^\infty{-e^{-x} \frac{1}{x^2}} dx [/tex]
It looks like this process is going to go on forever because I can't get rid of the 1/x term. Could someone please give some guidance on how this is done? Thanks.
You can't reduce it to a simple function using integration by parts. The integral defines a special function called the 'exponential integral', Ei(x).
Actually, the exponential integral Ei(x) is defined a little differently. See http://mathworld.wolfram.com/ExponentialIntegral.html for example. In any case, given your limits of zero to infinity, the integral diverges.
Ooops. Thanks for the correction. I didn't pay any attention to the fact it was a definite integral.
FAQ: Never ending integration by parts
What is "never ending integration by parts"?
"Never ending integration by parts" is a mathematical technique used to solve integrals that involve a product of two functions. It involves repeatedly applying the integration by parts formula until the integral can be evaluated.
When is "never ending integration by parts" used?
"Never ending integration by parts" is typically used when other techniques, such as substitution or partial fractions, are not applicable. It is also useful for solving integrals that involve trigonometric functions or logarithmic functions.
How does "never ending integration by parts" work?
The process of "never ending integration by parts" involves choosing one function as the "u" term and the other as the "dv" term. The formula for integration by parts is then applied, resulting in a new integral with a different "u" and "dv" term. This process is repeated until the integral can be evaluated.
What are the benefits of using "never ending integration by parts"?
"Never ending integration by parts" can be a powerful tool for solving difficult integrals. It allows for the integration of a wide range of functions, including products of functions, without needing to resort to numerical methods.
Are there any drawbacks to using "never ending integration by parts"?
One potential drawback of "never ending integration by parts" is that it can be time-consuming and tedious. It also requires a good understanding of the integration by parts formula and the ability to choose the appropriate "u" and "dv" terms for each iteration.
